Screaming eagle MM injection air cleaner kit
Old Feb 22, 2020 | 11:12 AM
mmyers321's Avatar
mmyers321
Default Screaming eagle MM injection air cleaner kit
Does anyone know the part number for a SE air cleaner kit for a 1996 ultra with efi or a set up that will work? Looking everywhere without any luck for a different ac kit. Thanks for any help.
Old Feb 22, 2020 | 03:13 PM
1997bagger's Avatar
1997bagger
https://accessories.harley-davidson....erformance-kit
Old Feb 22, 2020 | 03:16 PM
1997bagger's Avatar
1997bagger
I have the plate, filter and need to locate the bracket, will look tomorrow for the bracket. Live in Cincinnati
Old Feb 22, 2020 | 03:21 PM
mmyers321's Avatar
mmyers321
That is awesome, thank you very much!👍
Old Feb 23, 2020 | 08:11 PM
1997bagger's Avatar
1997bagger
Found it, need this JP Cycle part to complete it
https://www.jpcycles.com/product/974...her-kit-chrome
Old Feb 24, 2020 | 04:00 AM
mmyers321's Avatar
mmyers321
Sounds good, what were you looking to get for that? Thanks again!
Old Feb 24, 2020 | 10:35 AM
EVOrider's Avatar
EVOrider
You might want to consider the mm kits that were designed for the Twin Cams. They’re a little nicer. It does away with the cross-over tube. It works nicely on my 98 Ultra.
29441-99a
Old Feb 25, 2020 | 06:35 AM
mmyers321's Avatar
mmyers321
29441-99a
Which model exactly are you using? Everything I have found says it's a different diameter bolt/thread etc. Thanks!
Old Feb 25, 2020 | 10:41 AM
EVOrider's Avatar
EVOrider
I’m using this kit....use the breather bolts from the EVO. All four bolt holes must be the same on the throttle body....I believe two get a helicoil. It’s been a few years though....easy mod
Use a rubber spacer on the end of the air filter....so the round air cleaner cover or Twin cam style covers can be used.
Old Feb 25, 2020 | 08:40 PM
1997bagger's Avatar
1997bagger
$50 I work in Sharonville
