I'm converting a stock '90 FLHS to FLHR configuration. I've got the nacelle fitted up and a tank and instrument console mounted. Time to wire up the instruments. I have to figure out what I'm going to do about a speedometer. I've looked into Dakota Digital and can get a cable drive converter or inductive pickup to drive one of their speedometers. Cost will be $550 plus tax, minimum. Here's the question:
My FLHS has a cable driven mechanical speedometer and my transmission top cover isn't drilled for a speedometer pickup. Does anyone know if I can replace the top cover of my 5 speed transmission with a later model cover that's drilled for the OEM speedometer pickup and have the OEM pickup function with my 1990 transmission internals. I don't know what the sensor specifically detects within the transmission. If that would work I could then wire up the OEM sensor and use it to drive a stock Harley speedometer. It looks like that would be a whole lot cheaper than the Dakota Digital route which I'll do if I have to.
There's no realistic way to mount a mechanical speedometer into a Road King instrument console and I don't want to go to split tanks.
Thanks.
Frank
Thanks.
Frank
98hotrodfatboy
close
- Join DateMar 2010
- LocationPoolville
Liked:7,653 Times in 4,954 Posts
No you cannot just drill the cover.. infact the mounting area for the sensor is in the trans case. You would have to replace the case. Or if you go to a Baker OD6 builders kit the trap door can receive the hall affect pickup for the digital Speedo.. but then again I done believe Baker makes a builders kit for a 90 trans..
I had the same dilemma, so I decided to use a Speedhut GPS Speedo/tach. If you go this route,you will have to make a spacer as the Speedhut gauge is just a little smaller than the RK console.
grbrown
close
- Join DateJun 2007
- LocationBedford UK
Liked:2,898 Times in 2,450 Posts
Baker do make a builders kit for the '90 trans, I have a DD6 in mine, however I don't know if they can provide a speedo pickup for us.
Mountainkowboy
close
- Join DateJan 2006
- LocationAnywhere we stop
Liked:1,193 Times in 612 Posts
Thanks guys. I don't have easy access to a bike with a later model 5 speed so obviously didn't know where the sensor was. I guess the hole in the top cover must be for a shifting/gear indicator. I'm going to end up going the Dakota Digital route and will try the cable drive converter that MountainKowboy linked. If that doesn't work out I'll have to use one of the Dakota Digital inductive pickups for the rear wheel.
Appreciate the help.
Frank
Frank
GPS speed sensor would work, too with the electronic speedo of your choice, you could pick up a used speedo off a road king or a drag or twin reproduction
Dakota digital makes them
intellitronix is made in the USA for under $100
lots of made in China on amazon for cheap
I've read that the GPS speedometers can lose the GPS signals at times in cities, dense forest, etc. Any accuracy to that claim?
Thanks.
Frank
Thanks.
Frank
ExploreYankee Dog
close
- Join DateApr 2007
- LocationBrighton, MI
Liked:3,073 Times in 1,459 Posts
Quote:
Thanks.
Frank
I don't have a gps speedo, but I have a few different types of GPS (auto, hiking, etc) and yes you can lose signal. However, that signal loss only really lasts a minute or two when walking. Probably half that time while moving in a car or motorcycle. YDOriginally Posted by fshaw
I've read that the GPS speedometers can lose the GPS signals at times in cities, dense forest, etc. Any accuracy to that claim?Thanks.
Frank
Quote:
Thanks.
Frank
Frank, Originally Posted by fshaw
Frank
I haven't had a problem with my Speedhut losing signal. But I live in Lower Alabama where there isn't much in the way of high rises and tall dense forests.
Doug
