1340 evo speed issue.
Old Mar 18, 2020 | 09:49 PM
PKSSELL's Avatar
PKSSELL
Stage IV
Had a similar issue with my Dyna Evo. There is a pulley the throttle cable turns 90 degrees on just before the carb. The bolt that secures it had come loose and allowed the pully to move resulting in lost tension and a reduced WOT.
Old Mar 19, 2020 | 08:25 AM
Racepres's Avatar
Racepres
Originally Posted by texashillcountry
Nope all it will do is starve the motor at higher speeds.
BTDT
Not Lean you say????? same air... less Fuel????
If our Bike is too lean... for any reason... it "pops" not coughs like low RPM at throttle application... I mean at Higher RPM's
Old Mar 19, 2020 | 08:43 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
All I can tell you is my experience with a Super E.
I tried a 68 main and the bike ran fine but starved out around 70mph.
No popping at all just no acceleration past 70.
Old Mar 19, 2020 | 09:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I'll bet it did bog down though as you opened the throttle more to go faster in 5th gear...
I believe the term is called (fell flat on it's face)....
Old Mar 19, 2020 | 01:47 PM
WP50's Avatar
WP50
My 97 EG did fine running 70mphand could pass ok. When they jumped the speed limit to 75 and 80 mph around here.
It would run about 5 -6 mi and fall on it's face from time to time.
Found the float level had been set to low the season before. It was running the bowl dry
WP
Old Mar 19, 2020 | 01:54 PM
TwiZted Biker's Avatar
TwiZted Biker
Fuel delivery issue, enough to run lower RPM ranges ok but chokes off at higher draw. I'd start with pulling the petcock and checking the screen, do an intake leak test , then screw with the carb in that order.
Never just rip into a carb that was working before stupid started.....
Old Mar 20, 2020 | 09:08 PM
mike131's Avatar
mike131
I ran into this, do a compression test on it, mine would idle fine but would not go over 70mph, found low compression on one cylinder, took apart found a broken ring
Old Mar 25, 2020 | 06:25 AM
Gunslingertom's Avatar
Gunslingertom
I had an intake gasket leak did the exact same thing. If you're taking the carburetor off, it probably wouldn't hurt to change those intake gaskets as well.
Old Apr 6, 2020 | 12:02 PM
Pimp Daddy's Avatar
Pimp Daddy
When my 94 FXSTC had the same issue, it was a frayed throttle cable right up by the grip. Wouldn't allow WOT. I realize this has already been said, just throwing in my 2 cents.
Old Apr 9, 2020 | 04:00 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Pretty sure those petcox had a vacuum actuated valve. (At least the 1995's did.) Check to see if you have a vacuum leak to the diaphragm. (They were very problematic back in the late 1990's.) So much so, that the MOCO issued a recall...
Diena souper
Audio Systems
Apr 10, 2020 09:17 PM
MJHJEA
EVO
31
Feb 21, 2013 09:17 PM
swampking
Evo Era Parts
Dec 2, 2010 06:21 PM
dc1503
Oct 30, 2008 05:24 PM
pharmboy
Exhaust System Topics
Jun 13, 2006 09:03 AM
