1995 Dyna Wide Glide
Old Jul 24, 2019 | 11:40 AM
ThumbsUp20's Avatar
ThumbsUp20
Stage I
Default 1995 Dyna Wide Glide
I've got a 1995 Dyna Wide Glide and just replaced the battery. It keeps going dead after riding. How can I trouble shoot? What is the most likely problem?
Old Jul 25, 2019 | 11:09 AM
NoRegerts's Avatar
NoRegerts
I was going to try to explain but I found this article that explains it better than I could.
Old Jul 25, 2019 | 11:55 AM
nevil's Avatar
nevil
You should try posting in one of the tech areas. Unless you think your problem is bullsh**, because that's the section you're in.
Old Jul 25, 2019 | 02:02 PM
NoRegerts's Avatar
NoRegerts
I dang near spit out my drink onto my keyboard reading this.
Old Apr 9, 2020 | 06:27 AM
Nurselord's Avatar
Nurselord
Somehow posted to wrong thread...
Old Apr 9, 2020 | 11:06 AM
grbrown's Avatar
grbrown
The tech sections mostly get a thin response to queries, often getting no replies at all. There's no harm in asking in here, as there may be model specific problems to resolve.
It could be that your charging system is not working while you ride. There is a Sticky at the top of this Evo section, entitled "How To Diagnose Your Charging System". Work your way through that and report back on what you find. You will need a multimeter.
Old Apr 9, 2020 | 03:53 PM
NORTY FLATZ's Avatar
NORTY FLATZ
There's a "sticky" up above this thread.
"How to diagnose a charging system."
Go there.
Old Apr 9, 2020 | 07:20 PM
Yankee Dog's Avatar
Yankee Dog
https://www.hdforums.com/forum/evo-c...ng-system.html
As mentioned, if you follow the steps in the post (link above), you will get your charging system issue figured out. With the evos, a common but simple issue is the connection point where the voltage regulator plugs into the engine block. That connection point has a habit of coming loose, and the brass connectors heat up and melt. Sometimes hard to see without disconnecting it a really looking closely at both connectors. YD
Old Apr 10, 2020 | 06:50 AM
Architect's Avatar
Architect
Or just the voltage regulator itself, but it needs to be diagnosed, not just throwing parts at it.
Old Apr 10, 2020 | 08:15 AM
RANGER73's Avatar
RANGER73
As mentioned follow the diagnosis procedure in the sticky.
It's easy and will tell you exactly where your issue lies.
When I had a problem it was the Voltage Regulator and not the Stator.
OpposedOdie
Sep 18, 2017 12:27 PM
els43
EVO
Jun 15, 2013 04:30 PM
fb2005
Motorcycles For Sale
Apr 13, 2009 06:41 PM
cowentz
Feb 17, 2008 06:28 PM
