Obsolete Part Search
Old Apr 12, 2020 | 10:52 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by dixonk
Yeah I saw that one. Skittish on ordering reproduction products after this last ordeal with the JP cycles reproduction that isn't a true copy. For 80 bucks I may give it a go though.
Vtwin while import tends to be on the higher end of things quality & fit wise, most restore guys if they aren't going OEM exclusively uses Teds stuff.
J&P is just a bulk dropshipper they source from where ever, their name isn't on anything except the box.
Old Apr 12, 2020 | 10:55 PM
dixonk's Avatar
dixonk
So what's wrong with your speedometer, why do you need a new one?
https://www.ebay.com/itm/174241017066
Good find. I didn't think to cross reference with road king or dyna part numbers.
My speedo is cracked from me taking it apart to get rid of a dead bug that was stuck inside.
Old Apr 12, 2020 | 10:58 PM
dixonk's Avatar
dixonk
Good to know. Hopefully it is on par with the OEM part.
Old Apr 13, 2020 | 04:55 AM
t150vej's Avatar
t150vej
I have been trying to find a couple parts but these two parts are really stumping me trying to find.
67841-96A headlight
67027-96C speedometer
The speedometer my only solution was to find a 99 speedometer and get the wiring harness to convert it from terminal to 12 pin. I have the parts but the speedo is 10k miles higher than my original.
The headlight I bought a JP cycles "OEM" replacement but the bucket is not the same and it uses a proprietary clipped in halogen bulb and won't accept trim ring or bulb from original housing. Original headlight was dented at the back.
Could use a hand here trying to pin these parts down.
Ebay has lots of older stuff, NOS. You have to be patient and keep looking but usually over time, you can find almost anything you want. And look at the photos closely, sometimes people put part numbers on things that don't match the description.
speedometer 67410-99a
HEADLIGHT 67896-96A
Old Apr 13, 2020 | 07:13 AM
dixonk's Avatar
dixonk
HEADLIGHT 67896-96A
Those parts are for a dyna. The speedo is a 12 pin and the headlight doesn't look correct. Adjuster is wrong for the year and base looks too narrow.
Old Apr 13, 2020 | 07:30 AM
98hotrodfatboy's Avatar
98hotrodfatboy
HEADLIGHT 67896-96A
Doesn't that speedo kit come with a harness to go from duetch to later style connectors?
Old Apr 13, 2020 | 07:35 AM
dixonk's Avatar
dixonk
Yeah it will require a harness. I have a speedo from a 99 and harness. The OCD in me was just trying to find the correct speedo for the year bike. My speedo just says Harley Davidson Motorcycles along three bottom. In 99 and up the speedo says Certified Harley Davidson. I wonder if the dealer could add miles to a new speedo though.
Old Apr 13, 2020 | 07:45 AM
t150vej's Avatar
t150vej
Yeah, I didn't know. That's why I said be patient. Search by part number but verify with photos. Good luck in your hunt...
Old Apr 13, 2020 | 04:06 PM
nibroc's Avatar
nibroc
try oemnosparts.com
Old Apr 13, 2020 | 04:25 PM
TedMan's Avatar
TedMan
Originally Posted by nibroc
try oemnosparts.com
Linky no worky....
