I have been trying to find a couple parts but these two parts are really stumping me trying to find.
67841-96A headlight
67027-96A speedometer
The speedometer my only solution was to find a 99 speedometer and get the wiring harness to convert it from terminal to 12 pin. I have the parts but the speedo is 10k miles higher than my original.
The headlight I bought a JP cycles "OEM" replacement but the bucket is not the same and it uses a proprietary clipped in halogen bulb and won't accept trim ring or bulb from original housing. Original headlight was dented at the back.
Could use a hand here trying to pin these parts down.
Yeah I saw that one. Skittish on ordering reproduction products after this last ordeal with the JP cycles reproduction that isn't a true copy. For 80 bucks I may give it a go though.
