Voltage Regulators and Lithium Batteries
Old Oct 26, 2023 | 02:22 PM
  #71
Rains2much's Avatar
Rains2much
So new to me torn down built up 93 fxsts. (Replaced my 90 fxsts)
Put in a 640 CCA antigravity like was in the 90… this one the battery is going dead in one day, battery is hot to the touch. I DID FIND A LOSE MAIN BATTERY CABLE GROUND WIRE. Cleaned and tightened… but testing further to be sure it’s fixed.
I tested the stator as far as no ground. Charged the battery and it shows 13.2. Start the bike, dips maybe 12.99… raises to 13.2 but no higher. Kept the throttle at 2500 for 7 seconds. Still no higher than 13.2
thoughts?
Old Oct 26, 2023 | 03:34 PM
  #72
Yankee Dog's Avatar
Yankee Dog
Kind of lost as the thread is getting long.
What charging system components are new, what is not, what brand stator, what brand regulator, how old are the #4/#6 battery cables and ground wires? Should be getting higher running volts.
Old Oct 26, 2023 | 04:04 PM
  #73
Rains2much's Avatar
Rains2much
stock 93 fxsts charging system 10,300 original miles. New allballs starter and battery cables, new coil, new Antigravity battery. Problem “might” have been lose ground strap to negative battery terminal, but testing past this brings me to the thing not charging past 13.2 even while Reving motor. Motor is not stock, blueprinted assembled Ultima 127.
On charger it will charge to 14.26. On stator seems to cap at 13.2
Old Oct 26, 2023 | 04:15 PM
  #74
Max Headflow's Avatar
Max Headflow
So it's not charging.. Regular battery voltage for LI is about 13.2-13.3V.
Old Oct 26, 2023 | 05:24 PM
  #75
Yankee Dog's Avatar
Yankee Dog
Stator/Regulator new? Brand?
What is stator output in ac volts at 1000, 2000. 3000 rpms?
Old Oct 26, 2023 | 06:06 PM
  #76
Rains2much's Avatar
Rains2much
Stator/Regulator new? Brand? To the best of my knowledge stock 1993
What is stator output in ac volts at 1000, 2000. 3000 rpms? At 2500 it goes to 13.26 and no higher
As typed above.
Old Oct 26, 2023 | 06:38 PM
  #77
Yankee Dog's Avatar
Yankee Dog
AC VOLTAGE (not dc voltage).
Also when measuring AC VOLTAGE (not DC voltage) it is measured at the connector at the engine block.
Disconnect the connector that the regulator plugs into at the engine block. Set your meter for AC VOLTS, start the bike, touch one probe to one of the female pins (actually a socket) and the other probe to the other female. Does not matter which probe goes to which pin, just don't short the pins with the probes (don't touch them together while running). A safer method is to make a couple pig tails using some insulated wire inserted into the small brass sockets and connect the pigtails to your meter probes.
You are measuring the AC voltage that the stator creates before any voltage gets to the regulator/rectifier. If your AC VOLTS is in spec, then the next step is to check the regulator, but start with the stator first by measuring the AC volts. It is easy to do and AC volts should increase with engine RPM.
Follow the Dr. Hess instructions posted here and you will find the problem:
https://www.hdforums.com/forum/evo/8...ng-system.html
"Set meter to AC Volts, 100V scale. Attach each meter lead to a stator pin. You may need to rig up some type of temporary plug. It is important that nothing can short to ground or to each other accidentally, or you will blow the stator if it wasn't blown before. An old plug off of your last regulator is a good way to do it, but, get creative and be careful. I can do it holding the leads on the pins once the bike is running, but I don't like to. Start bike. Voltage should vary with engine speed. Specs are in your shop manual, but 35V at a couple thousand RPM is probably about right. My book says 19-26 V / 1K RPM."
Old Jan 5, 2024 | 11:47 AM
  #78
gid58's Avatar
gid58
Default 13.2
Is this an AntiGravity Lithium?? What Reg?
Old Jan 8, 2024 | 11:33 AM
  #79
Rains2much's Avatar
Rains2much
I never followed up. I replaced the stator and voltage regulator with new Ultima parts and I’m 2300 miles into zero problems. Charging perfectly.
Stromhammar
Dec 21, 2022 07:57 PM
Florida Swamp Yankee
Electrical/Lighting/Alarm
Mar 31, 2014 01:09 PM
FL-kruzen
Mar 28, 2012 06:46 PM
Sleeps In Trees
Oct 12, 2008 04:48 PM
gsparesa
Dec 16, 2005 01:17 AM
