Voltage Regulators and Lithium Batteries
Old Apr 28, 2020 | 02:40 AM
fshaw's Avatar
fshaw
Default Voltage Regulators and Lithium Batteries
I moved the battery under the seat of my 1990 FLHS and purchased an Antigravity battery to get the CCAs I wanted in the space available. A warning on the battery said “Do not use in motorcycles earlier than 1990 without upgrading the voltage regulator or a fire my occur.” My bike is a 1990 so no problem there, but as I read the J&P catalog some regulators that fit a 1990 Evo also fit earlier bikes including alternator Shovels. I have a Cycle Electric stator and a Twin Power regulator that fits 88 and later Evos. Anyone have an idea what the ”1990 upgraded voltage regulator” is?
Please no “Should have just bought a lead-acid or gel mat battery.”
Thanks.
Frank
Old Apr 28, 2020 | 03:23 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The only thing likely to cause a fire in a lithium battery is overcharging or applying a much higher voltage.
I can only guess that early regulators do not give out a smooth constant voltage and rely on the battery to complete the circuit.
Years ago on a bike I had it could be kick started without the battery being connected but the voltage was high enough to blow the neutral bulb.
Old Apr 28, 2020 | 05:29 AM
grbrown's Avatar
grbrown
The Shorai in my 1990 FLHS hasn't blown up yet, although it hasn't had much use yet.
Old Apr 28, 2020 | 06:03 AM
RANGER73's Avatar
RANGER73
I'd be curious to know why also.
Old Apr 28, 2020 | 06:46 AM
0maha's Avatar
0maha
I also put an Antigravity in my FLHTC. Mines also a '90.
Don't recall seeing the warning. I also don't recall there being any great leap forward in charging system or voltage regulator technology in 1990.
Long before I converted the battery, my VR died and was replaced. The volt meter on the dash allowed me to catch it early. When it quit, the meter was fully pegged on the high side.
Any how, I've only run this battery for one season, and so far, so good.
Old Apr 28, 2020 | 07:24 AM
Andy from Sandy
This could also be what has changed that if the VR fails it does it in a way to not put out a high voltage. To the end user there is no apparent difference.
Old Apr 28, 2020 | 08:10 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Nope.
I've seen a twinkie that the regulator failed on the high side.
I'm sorry that I don't know the answer to your original question but the VR being changed to not fail on the high side isn't it.
Old Apr 28, 2020 | 09:41 AM
t150vej's Avatar
t150vej
The pre 89's were a 22 amp system from the factory - totally different regulator circuits from the post '88, 32 amp systems. And yes, the 22 amp systems can fail in a way to put out excessive voltage.
The 32 amp systems can also be installed in the older models, which many of us have done.
Old Apr 28, 2020 | 10:30 AM
hvacgaspiping's Avatar
hvacgaspiping
Correct. However, the key to preventing an overcharge is precise voltage control. So, a voltage regulator that accomplishes that is extremely important. The same can be said for a trickle charger which is usually left connected for long periods. There are also some lithium motorcycle batteries that do not have built-in safety measures which protect from overcharging and non balanced charging of the individual cells. Those non protected ones are dangerous and put the user/device at extreme risk of fire. Make sure any motorcycle battery you buy these days has these protections. Here is a good article to check out: http://www.fastbikegear.co.nz/index....d=18&chapter=1
Old Mar 25, 2022 | 09:39 AM
guru.v's Avatar
guru.v
Please help.
What is the output voltage of a lithium battery.? i
Is it 11.1volts
or 14.8volts.
For the charger of the bike charges at 14 volts
The electronics on the bike woks at what then
