Cam ID without removing it?
Old Jun 26, 2020 | 09:04 PM
Adam76's Avatar
Adam76
Originally Posted by 0maha
You can pop a pushrod tube cover and see if you've got adjustibles in there. If you do, you can be reasonably certain you've got an aftermarket cam of some sort. Which one is, of course, anyone's guess.
If you want to know exactly which one you've got, you're going to have to pull it out.
thanks, I've had a look and they are the stock PRs. Doesn't necessarily mean someone hasn't done a cam change from the top end? Unlikely though. But I'm thinking it's possible as the is a mikuni carb and a crane HI-4 ignition, so you never know?
Old Jun 26, 2020 | 09:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Unlikely?
Not everyone follows the internet idea that adjustable pushrods are the way to go.
If you pull a pushrod cover on my EVO, you`ll see stock pushrods, but if you pull the cam, you`ll see an EV27.
It`s a great cam.
Old Jun 26, 2020 | 11:05 PM
TwiZted Biker's Avatar
TwiZted Biker
huh? The 27 is almost a hall of fame all round winner for this motor, stock or mild build.
What would you suggest, I'm curious??
What style bike, heavy, dyna, sloptail ? and what's your riding style ? Choices are many depending on the answers to those.
EV-27 is high rpm cam doesn't come on till 3500 rpm and most people live under that in general daily riding habits.Only time you notice is hot rodding in higher RPM"s all the time or high highway pulling. In the 80's & early 90's it was the **** because it was the most common and easy to get.
Old Jun 26, 2020 | 11:26 PM
Adam76's Avatar
Adam76
Unlikely?
It`s a great cam.
thanks dan89, 👍
Old Jun 26, 2020 | 11:30 PM
Adam76's Avatar
Adam76
it's still one of the best cams for a mild build..... it's definitely NOT a high rpm cam, and set with 9.5 comp it's still one of the best combinations out there pulling from 2000rpm with many builders still recommending this combo today, and probably will be tomorrow. You want a stump puller for a heavy bike? Then sure the ev13 might be a better option..... but let's not get into another cam debate 🙄
Old Jun 27, 2020 | 05:22 AM
98hotrodfatboy's Avatar
98hotrodfatboy
There's no way that cam starts pulling at 2,000 RPM... pull your heads out of the clouds.....
Old Jun 27, 2020 | 07:33 AM
Adam76's Avatar
Adam76
OK, l was exaggerating a little there..... But what I meant was with some compression surely it would come on well before 3500rpm previously mentioned?
Old Jun 27, 2020 | 07:36 AM
Adam76's Avatar
Adam76
Bike is a softail, and I still can't agree with you stating the ev27 is a high rpm cam.
If there are so many better choices now, what are those you consider better?
Old Jun 27, 2020 | 08:02 AM
RLH3175's Avatar
RLH3175
absolutely part of the plan. Thank you.
Just don't want to go to pot in an ev27 just to find there's an ev27 already in there. 😁
That is exactly what I did, ordered the ev27, tore it down to put it in, and it already had a ev27 in it.
grbrown's Avatar
grbrown
Thumbs up
I agree. The EV27 is well known as a great all-rounder IMHO, which is why I used one for several years in my Glide. I understand it will work better with a little extra CR, but hey, the rules of tuning are there to be broken. I now have an S&S V107T which came stock with their 585 cam and a low CR. Built as a touring engine and run-in it is great and remarkably tolerant of riding at very low engine speeds - I love it. However I have had 'arguments' with experts in HDF that it is actually a high-rev cam, needs lots of CR, etc. Rubbish, what do they know?! It's great in the form I have it. So take assessments of what a cam is good for with a packet of salt. There are better cams than an EV27, when used with well-tuned heads and CR, but they are best sorted out with someone like HDF sponsor Hillside Cycles.
