Primary Locking Bar Length?
Old Jun 30, 2020 | 05:19 PM
Mountainkowboy's Avatar
Mountainkowboy
IIRC I used a 3/8's ratchet on the 89......fit perfect and locked it right up.
The turnbuckle would work pretty good too, the right size should be 1/4-20, so the rounded part of the loop should fit in the teeth pretty close.....just loosen it up till it's tight against the teeth.
Either way I started makin mine.
Old Jun 30, 2020 | 06:48 PM
Dr.Hess's Avatar
Dr.Hess
Originally Posted by texashillcountry
Why would you use a turnbuckle to lock your primary?????
Hell how would you use a turnbuckle to lock your primary???
You use a turnbuckle because it works well and is cheap. You just expand it out until the eye ends lock in the sprockets, then crank away at the compensator and clutch hub. You, of course, need a large turnbuckle. That's how I used to do it before I got an air compressor and a rattle gun.
Old Jun 30, 2020 | 08:20 PM
mike131's Avatar
mike131
I just use a piece of 1x2 wood angled between compensator teeth and primary teeth
scoop_fraser
Feb 2, 2020 09:53 PM
Pothole914
Oct 3, 2016 07:32 PM
hardheaded
Dec 4, 2013 08:31 PM
xwhyz1959
Aug 11, 2012 03:46 PM
JefFLH
Nov 16, 2010 05:18 PM
