Rear wheel install
Old Jul 12, 2020 | 06:42 AM
roszko2@yahoo.com's Avatar
roszko2@yahoo.com
6th Gear
Default Rear wheel install
All, I’m having issues with an install of my rear wheel on a 97 road king.
I had some new tires put on and after reinstalling my rear wheel, the sprocket rubs on the swing arm once the nut gets anywhere close to torqued.
The wheel is aligned, when checked at 15 or so ft/lbs, larger wheel spacer is on belt side. I’m at a loss I’m assuming it’s a simple solution that I just can’t see.
thanks
Old Jul 12, 2020 | 06:46 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Was working before properly ,check the spacers, you assembled wrong.
Old Jul 12, 2020 | 07:15 AM
roszko2@yahoo.com
6th Gear
That was my thought too. Are the inner spacers same size? Thought they had same part number?
Old Jul 12, 2020 | 07:36 AM
V-Twins & Bowties
take a look at Ronnies micro fiche , online , see if that helps.
Old Jul 12, 2020 | 08:39 AM
roszko2@yahoo.com
6th Gear
Looking at the fiche, it looks as though there should be 2 “spacers” outside the wheel on the left? I can’t seem to wrap my head around it.... damn concussions
Old Jul 12, 2020 | 09:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You have 2 spacers that are the same size, one on each side, they go up against the bearing inner race.
The left side has an additional spacer that goes outside of the first spacer.
You are missing one of the spacers.
Old Jul 12, 2020 | 10:16 AM
t150vej's Avatar
t150vej
Originally Posted by roszko2@yahoo.com
I had some new tires put on and ..........
Unless you took the inner spacers out of the seals before the trip to the tire store, good chance one of your spacers in on their floor, or in whatever vehicle you drove there...
And you should ALWAYS service wheel bearings before installation, after changing a tire
Old Jul 12, 2020 | 10:56 AM
roszko2@yahoo.com
6th Gear
It looks like I have all the parts. 2 inners a larger and a smaller outer.... Ill try and reinstall I guess 🤷🏼‍♂️
Old Jul 12, 2020 | 11:06 AM
t150vej's Avatar
t150vej
There are the 2 that fit into the seals, long one on the pulley side and the caliper mount is the spacer for the right side. What's this smaller outer you mention?
If it's a thin, stepped washer looking thing, that goes between the inner bearing spacer and a bearing.
Did you take the wheel bearings out?
Old Jul 12, 2020 | 11:42 AM
roszko2@yahoo.com
6th Gear
I didn’t take the bearings out. The bike isn’t in front of me right now. I’ll take some photos when I get home.
