Rocker box leak
Old Aug 8, 2020 | 07:59 AM
GOGOBECK's Avatar
GOGOBECK
Default Rocker box leak
I’ve developed a small oil leak. It appears to be coming from between the seams in the rocker box covers. It has done it twice, both times following an extended warm up time before riding.
Yesterday I warmed her up for maybe 10 minutes, drove 15 miles and stopped for gas... no leak.
I stopped again after about 30 miles from fill up and I had about eight gallons of oil spewed on the inside of my right leg, the side of the seat and the side cover and saddle bag lid. Okay maybe it was only 1/4 teaspoon of oil!
I rode it once in between the two oil incidents, without an extended warm up... but I putted really easy until she came up to temp. Rode about 100 miles with one stop at about 45 miles... no oil spewing.
Its not coming from the air cleaner, that’s clean as can be. It appears to be from the rear cylinder, right rear corner of the chrome valve cover.
Can I, should I, tighten the valve cover fasteners a bit beyond the recommended torque value? I replaced these several years back with polished SS fasteners with the thin copper washers under a SS washer, at the time I believe the spec called for a bit more or a bit less torque than the service manual calls for.
99k miles first leak she’s sprung!
Old Aug 8, 2020 | 09:14 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I would replace the gaskets and also do the umbrella valves.. Honestly I've never tried to properly torque the screws.. I've been wrenching most of my life so I get them to where they are tight but not stretching the threads...
Old Aug 8, 2020 | 10:34 AM
t150vej's Avatar
t150vej
I'd check that one screw closely. It may be that screw leaking and looks like it's at the seam - seen that a lot. The way the air moves over/around these engines will fool you with cover leaks.
I've always had best luck with the soft thick fiber washers (oem) under thick flat washers. As as far as torque - when the cover screws are drawn down evenly, 1/4 turn at a time, the cover will bottom out and you will feel screw simply "stop." At that point there's no need going any further. OEM rubbers behave that way very consistently. Most aftermarket rubbers are a tick thicker and harder which makes it more difficult to "feel" the stopping point.
So check your screw(s) first. If they are dry and snug, go with replacing the rubbers next.
Old Aug 10, 2020 | 09:25 PM
TedMan's Avatar
TedMan
Just went through this but coming from the front. New set of updated oem gaskets and umbrella valves fixed it. Good luck.
Thund3rbolt
Jul 28, 2019 11:56 AM
cruiser66
Exhaust System Topics
Jan 7, 2016 02:49 PM
20071200C
Jul 19, 2012 05:38 PM
Old Texas Gringo
Jul 30, 2008 11:23 AM
Gromit
Dec 6, 2005 02:12 PM
