Regulator/Rectifier Question
So my question is this, will this regulator work? According to the website it's an exact fit. And more importantly, will this fix my charging issues?? I really want to trust this bike.
https://www.denniskirk.com/cycle-ele...prd/H21883.sku
Thanks for your help..
This isnt an area I recommend changing parts to take care of the problem. Gets expensive and sometimes doesnt take care of the issue.
Troubleshoot the right way....then try to figure out what caused the part to fail.
After a long ride (or at a stop during a long ride), have you used a volt meter at the battery terminals to see what the charging voltage is with the engine running?
Volt meters/multimeters take the guessing out of what's going on with the electrical system.
Buy one and learn how to use it if you don't know how, to save yourself some $$$ throwing money at parts you don't need..
The starter was replaced last year with a Spykes starter. I opened the starter and everything is connected properly and solenoid looked fine.
My fear might be reality. I think there's a wire somewhere in the harness that is grounding out or something. On a full charge after being on the tender, when I hit the start button, there is a rapid clicking while the engine is being turned over. So now I need to go through the entire wiring system. This has been an ongoing issue with this bike since I bought it in 07. The engine was replaced by the original owner(Hot Shot 107), and then I replaced that motor with a S&S 113. So who know what's really going on in there. I think I'll take it to a shop when I get the funds, and have them do a complete rewire after I swap the regulator on Monday.
I really want to be able to trust this bike.
Stator tests can be misleading. That is, it can check not shorted and voltage output but still have a deficiency. Oil is an insulator and can hide a bad spot on the winding and while running allow the short to occur intermittently. Also, the regulator can let A/C voltage thru if it's defective which won't charge the battery.
The tests in the sticky at the top of the Evo forum page are excellent. https://www.hdforums.com/forum/evo-c...ng-system.html
If you're satisfied it passed all that, I'd put an analog volt gauge (with a needle) on it temporarily tied to the handlebars or somewhere you can see what is actually going on with the system while riding. Again, a failing stator can "pass" a static test but still not charge under load especially after it's up to running temperatures. A dirty or bad connection at the stator/regulator plug can be an issue causing intermittent charging problems.
The troubleshooting process will tell you what is most likely failing.
You appear to still be guessing.
You don`t need to go through the entire wiring system, you need to first find out exactly what is making the clicking noise, that will narrow it down considerably.
It is either a breaker, the start relay, or the starter solenoid. You need to get your hands on them and find out which it is.
Take a deep breath and let us help you through it.
If it were a wire grounding out, it wouldn`t matter how much charge the battery had.
That is an absurd idea. Your troubleshooting ideas have no logic because you don`t understand how the electrical system works.
