Mikuni Help
Old Nov 13, 2020 | 11:39 PM
Jake707's Avatar
Jake707
Default Mikuni Help
Hey guys. I just picked up another fxr and I’m looking for a little bit of clarity. It’s still 80” evo with thunderheader and EV 27 cam. It has a Mikuni 42 on it which is foreign to me. Came from MN to me here in CA so could have been tuned right up there but def not here haha. Runs ok, idle seems to be fine but any hard throttle and wants to die. Crack full throttle and not let go right away it will.
Pulled the main jet and it’s a 160. Two of the bowl screws are stripped so I haven’t been able to open it up to see about everything else. Mixture screw is one turn out, anything more or less and it idles rough or wants to die.
Ignition wise it’s a S&S HI-4N set at mode 5 and advance rate at 9. Coil is the Andrew’s red 3 ohm coil (dual spark I think?)
that’s the details I have now hoping someone can tell me the “typical” killer combo for this set up. The jets and parts aren’t expensive but shipping takes forever so I’d rather order everything and spend an extra $5 for something I might already have then have to wait another week to order another piece.
Old Nov 14, 2020 | 05:31 AM
RANGER73's Avatar
RANGER73
There's a Mikuni manual online you can print. Also there a write-up for jetting for better mileage.
I just installed a HSR42 on my 94 Softail. Same setup as you.
Andrews cam EV27
S&S ignition, single fire coil
Good right out of the box
The tuning book explains the adjustments for jetting to fix your issue.
Old Nov 14, 2020 | 06:11 AM
98hotrodfatboy's Avatar
98hotrodfatboy
A 25/170 should be more than enough for what you have in that. Unless there is at least a 5,000 ft elevation difference between the previous owner and you, I highly doubt that that's the issue, most likely dirty carb just needs a good cleaning... Also not a big fan of the high four ignition.. Known to have issues.
Old Nov 14, 2020 | 06:41 AM
carlgrover's Avatar
carlgrover
So I put a Mikuni on my ironhead and it wouldn't run worth a crap. I pulled it off, took it apart and dunked it in a gallon can of carb cleaner you can get at any auto parts store. It has a little basket to hold small parts too. After a 3 hour soak, cleaning in water and blowing out dry with compressed air, I put it back together and it ran great with no adjustments.
So before you do any adjusting on that carb, dunk it in that cleaner first. I've tried cleaning them using the spray cans and it doesn't work like this stuff does. Not very expensive either.
carl
Old Nov 14, 2020 | 09:10 AM
98hotrodfatboy
Carb cleaner in a paint can..
https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds
Old Nov 14, 2020 | 01:56 PM
Jake707's Avatar
Jake707
Thanks for the replies. Yea I have been reading the manual and it gets a bit overwhelming after awhile haha and I can’t ride it right now due to rain.
just took the carb apart and I’m going to clean it real good.
found out
pilot jet is a 25
needle is a 97 on the third (middle) clip
needle jet is a 6 series (Y-6)
Old Nov 14, 2020 | 04:34 PM
Architect's Avatar
Architect
Those stripped screws on the bowl are for a Japanese phillips head screw driver, standard screw driver will strip them every time. Do a search, people sell allen head replacements so you can get them on and off again with all of the BS. I had to use a vise grip to get mine off, not fun.
PS have the same setup in my '97, worked just great out of the box, good luck.
Old Nov 14, 2020 | 07:24 PM
Jake707's Avatar
Jake707
Ok cleaned the carb up good, put in a 165 main, kept the 25 pilot and moved the needle up so the clip is on the 4th down
at idle the mixture screw seems to be best at 1.5 turns.
im not using VOES and it was just cut before so it forced the hi-4 to use the retarded version of the curve. I grounded the wire now so it used the advanced version. Haven’t been able to ride it yet but in the garage it seems to respond pretty good. Except if I hit the throttle off idle hard it sometimes gives a backfire in the carb.
I need to test ride it and see if there’s pinging but the carb backfire has me confused.
Old Nov 14, 2020 | 08:03 PM
RANGER73's Avatar
RANGER73
Try a 17.5 pilot a 150 main is stock and a 98 clipped at center for your setup and better gas mileage
Old Nov 15, 2020 | 06:29 AM
1997bagger's Avatar
1997bagger
Andrews cam EV27
Joe Minton wrote the Mikuni manual for them, he also has recommendations "Joe Minton mileage set kit" it works.
A pop out the carb is a lean condition, back fire could be a timing issue but most likely lean
