Evo no start
New coil and it fires up better than it ever has. Try a high output coil before tearing into it if possible.
Since you have replaced the carb, that would be my next step.
Griz
I suggested earlier he change the coil since he has borrowed an ignition and carburetor. I wouldn't think a stock coil we be that hard to source.
Come to think of it, it had an Ultima nose cone module when he started on it. If the PO installed it and the coil came with the module, I can attest that those coils are usually junk. Mine lasted about 200 miles and I've heard bad things about them since.
for the too much fuel hydro locking comment would love to know what that means and how to troubleshoot it
also for the suggestion above for using jumper cables did you mean like to try to jump it off a car battery?
Do you have a timing light? If so, you should try Hess' suggestion and see where the spark takes place on the flywheel.
Is your ignition module in the nose cone? When you installed/timed it, were you in the middle of the adjustment range, or close to one of the ends?
Yes, car type jumper cables, about $15-$20 at the chain parts stores (Advance, Oreilys, Autozone etc)
Take the ignition module out - don't disconnect it. Take out the screw holding the timing rotor to the cam. Pull it out and make sure the dimple next to the screw hole engages the notch in the camshaft, replace the screw and module.
Next, download / copy these instructions and follow the Static Timing procedure - to the letter. https://www.wwag.com/step/pdf/123271.pdf
Also, verify the wire connections on the bike. You really only "need" white and pink (for the dual fire coil) blue is used for the single fire operation, green goes to tach, purple goes to the VOES but you said it's unplugged at the hose.All that's in the install sheet and don't worry about the switches, just make sure they are all off (down) for now.
0maha types faster than I do... his bike is probably faster too
going to try the car battery jump next as the last step.
checked the cylinders there is not fuel collecting. Just a little droplets from all trying to start with the net rocket. The droplets were clear and did look like oil but cant say for sure. Will report back this weekend once I get a little more time with this .
if I plug the vacuum port with my finger then it dies. Not sure whats going on there. Also have to set up idle etc. But at least this tells me that the motor is fine and that fuel delivery is the issue.
