EVO EFI Idle speed
Old Apr 21, 2021 | 09:54 PM
1997bagger's Avatar
1997bagger
Originally Posted by Dano523
Walk in the park.
Not the right screw for the warm idle, you have to take the backing plate off the air cleaner to gain access.
Old Apr 21, 2021 | 10:29 PM
EVOrider's Avatar
EVOrider
Yea....the cold idle set screw is up top and the hot idle screw is lower right hand corner of the throttle body.
The set screw isn’t always an Allen either....lots are Torx.
Harley went through several idle setting procedures before dumping that system in 2001. Of course, some have their own way of setting the idle. I finally settled on the 2001 way.....it stays that way longer I my opinion.
My opinion.....confirm the TPS is set correctly. If the screws are still filled with glue, chances are it’s set right. Definitely worth checking. There’s a great YouTube video showing the TPS adjust.
Old Apr 22, 2021 | 11:34 AM
carlgrover's Avatar
carlgrover
I have stage I on mine so my backing plate is aluminum. I drilled a hole in it so I can adjust the hot idle without removal.
carl
Old Apr 22, 2021 | 09:21 PM
1997bagger's Avatar
1997bagger
carl
Yes sir, used the gasket for a template to drill the hole, also noticed engine idle would drop 100 rpms when putting the air filter back in.
Old Apr 23, 2021 | 07:25 PM
carlgrover's Avatar
carlgrover
I never noticed a change in rpm on mine with the air filter going on but then I think my tach isn't all that great.
carl
Old Apr 23, 2021 | 07:39 PM
EVOrider's Avatar
EVOrider
With the factory air filter and the factory backing plate....I did notice a difference in RPM.
With the SE air filter and their backplate....my RPM stayed the same after resetting the idle.
shovelhead FXEF
EVO
Apr 21, 2021 08:44 PM
mhenry
Mar 31, 2012 06:01 PM
hatchetman
Jan 26, 2009 10:56 AM
king96
EVO
32
Apr 22, 2008 04:38 AM
Two_Into1
Exhaust System Topics
Jun 2, 2006 10:36 PM
