Front shocks sucking air
Old May 1, 2021 | 06:31 AM
Kerpdog's Avatar
Kerpdog
5th Gear
Default Front shocks sucking air
Hi Folks,
I recently bought a 1995 Electra Glide Ultra Classic. When I'm backing the bike down from my parking pad, the slight incline causes the front suspension to extend when I use the front brakes. As the shocks extend, I hear a loud air-sucking, slightly gurgling sound from the front suspension. When the shocks re-compress there's a slight hum, like air through a reed. Is this normal? Any thoughts whether there is something I need to address? The bike just passed my state's safety inspection, and the guy who did it said he thought the suspension felt a little mushy, but I didn't think to ask him "front or rear?"
Thanks.
Old May 1, 2021 | 06:44 AM
eighteight's Avatar
eighteight
Your bike has air adjustable forks, ( the reservoir is either the handlebar or crashbar depending on year ) incorporated into them is an anti dive solenoid ( google it for more complete explanation)
i rather suspect this is what you`re hearing ( engines is OFF right ? )
YES , with stock springs and / or oil they are mushy
Old May 1, 2021 | 11:32 AM
blumi's Avatar
blumi
Aloha,
sounds like not enough fork oil in the tubes.
My bike don't make this noises when moving.
I always replace all fluids when I bough a new used car or bike.
That's why my recommendation change the oil.
It's a little more work cause the fairing but it makes absolutely sense to do.
For more pictures you can see my album where I change the fork lock and steering bearing.
Old May 2, 2021 | 03:33 PM
Kerpdog's Avatar
Kerpdog
5th Gear
Hi eighteight,
Thanks for your response. Yes, engine off. Your answer sent me to my factory manual where I only found a little help. It shows an air valve on the end of the left hand grip, but that is missing on my bike. I suspect one of the previous owners must have removed all or part of the system in order to install grips they liked better. But now I know where to start digging, so thank you.
Kerpdog
Old May 2, 2021 | 03:38 PM
Kerpdog's Avatar
Kerpdog
5th Gear
Hi Blumi,
Thanks for your response. Replacing all fluids is good advice, and I'm going to get to all of them in due time. Since the fairing has to come off, I'm going to stage a number of things under there... troubleshoot oil pressure gauge, try to figure out where unconnected wires dangling under the fairing might go, maybe even install the factory style of handlebars instead of the ape hangers someone put on the bike, etc. The last guy to own it was a bit haphazard in his work.
Kerpdog
Old May 3, 2021 | 12:04 PM
grbrown's Avatar
grbrown
Use your FSM to follow the front fork air system. When stock there is a short rubber hose from the centre of the bars to a manifold, mounted on the fork caps. The noise you hear may simply be a leak, or due to part of the above being removed but not capped.
Old May 3, 2021 | 12:43 PM
eighteight's Avatar
eighteight
Go to Ronnies Parts finder for exploded view of all the "widgets"
Old May 4, 2021 | 12:13 AM
blumi's Avatar
blumi
Hi Kerpdog,
when I read Ape hanger than I believe this Ape has not the access for the air tube as the original one.
That explains why there is no valve at the left side.
I promise you that's all you have to fix including new oil.
Without the air tube the air in the fork can't get compressed and that makes a bad feeling and noising when moving the bike.
So next step, remove the outer fairing and check the left side for the rubber tube and if it's there.
Old May 16, 2021 | 10:22 AM
blumi's Avatar
blumi
Aloha,
have you checked the air tube connection and changed the oil?
Any other news?
dugy40
Nov 21, 2020 03:47 PM
manzo
2014-2024 Touring Models
Mar 18, 2014 07:08 PM
praenomenpaul
Aug 8, 2009 01:28 PM
broncorckcrwlr
Mar 1, 2009 12:02 AM
MikesDad
Aug 15, 2007 01:02 AM
