Melting Battery Terminal
Old May 21, 2021 | 02:00 PM
mike131's Avatar
mike131
I agree with the statements above, the only thing I have to add is I've had the starter run away from low battery voltage or a bad battery
Old May 21, 2021 | 02:19 PM
Dr.Hess's Avatar
Dr.Hess
All good advice. And if the cables are good, connections are good, I'm thinking the starter is about shot. Having an 86 myself, I replaced the starter with an All ***** and it's great. Spins that motor like a top now.
I would also suggest measuring the current going through the battery cable when you crank it. I have the top of the line Harbor Freight clamp on digital multimeter, and it will read DC Amps, peak and instantaneous. Should be around 100 amps peak. If it's 200, there's your problem (starter.)
Old May 21, 2021 | 06:39 PM
mentalite's Avatar
mentalite
I can't thank you guys enough. For now I'm going to focus on the connections and the starter amperage. The solenoid is new so I'll hope that isn't bad.
Old May 21, 2021 | 07:37 PM
TwiZted Biker's Avatar
TwiZted Biker
I'd replace the big flex ground strap underneath just because. Corrosion you won't see plays havoc with conductivity. Wire brush all grounding points and problem bikes I use thin star washers between the cable & ground points.
Old May 21, 2021 | 07:48 PM
guido4198's Avatar
guido4198
Definitely. Replace, scrub/ clean/ freshen contact points and add those star washers,
” Just Because “.
Old Jun 10, 2021 | 08:14 PM
mentalite's Avatar
mentalite
Since I always get disappointed when a help thread doesn't resolve with the final solution, I thought I'd bring some closure to this one. Starter. It had an aftermarket All ***** starter that was pulling too much amperage. I could hear it engage, but it would just make a whining noise even after letting off the start button. Then it would suddenly kick over after a few seconds. Well a new stock style starter fixed it right up. When I took the old starter apart it smelled horrible and had a lot of dust in there that resembled brake dust. Some insulating material of some sort that got overheated maybe?
I had considered the possibility that my new batteries had insufficient CCA ratings. It wasn't the case for me, but be aware that some of these aftermarket high torque starters require stronger batteries and fatter cables.
Old Jun 13, 2021 | 08:06 PM
GREENOHAWK69's Avatar
GREENOHAWK69
I hope you contacted All ***** with your receipt/documentation as they do replace their starters - I did this and have their 1.7kW starter. Cost me shipping to them.
Old Jun 14, 2021 | 07:22 AM
mike131's Avatar
mike131
I've been hearing people having problems with All ***** starters, drawing excessive amps ect, something to look into
SouthBayRay
Electrical/Lighting/Alarm
Jun 3, 2016 06:42 PM
DEric24
Jul 3, 2015 08:53 AM
stephtell
EVO
13
Mar 2, 2015 09:20 AM
hey stoopid
Feb 15, 2011 05:20 PM
marl3y
Apr 28, 2009 08:10 PM
