Can someone identify this sound?
Old May 21, 2021 | 08:04 PM
Windseeker's Avatar
Windseeker
Default Can someone identify this sound?
I just took the '94 Fatboy out for about 5-6 miles. I noticed I was hearing a sound that shouldn't be there. It was sort of a huffing, puffing, hissing sound, and by the time I got back home, it was twice as loud as when I left.
I don't have YouTube, but I made a video on my phone. You can especially hear it when I go around the back of the bike. It's that steady hissing sound.
Click to see and listen:
http://www.southtech1644.com/files/FatboyPuffing.mp4
So what do you think? Exhaust leak? Vacuum? Something really bad like a head gasket?
Please advise.
EDIT: I forgot this part. The power of the bike doesn't seem diminished at all.
Old May 21, 2021 | 08:17 PM
daven9113's Avatar
daven9113
Did you check the head gaskets? Any oil leaking?
Old May 21, 2021 | 08:19 PM
Windseeker's Avatar
Windseeker
Not just yet. This only started less than an hour ago.
The bike only has about 36,000 miles. I know that may not mean much, but that sounds low to be having head gasket issues, doesn't it?
Old May 21, 2021 | 08:25 PM
0maha's Avatar
0maha
Do a compression check.
Sorry to say, what I heard sounds head gasket to me. But diagnosing this stuff long distance over an android phone isn't reliable.
Comp check won't lie.
Old May 21, 2021 | 08:31 PM
Windseeker's Avatar
Windseeker
Okay, let's sat that this is the correct answer, and it very well may be.
In that case, the most important question is:
Does the engine have to be dismounted and removed from the frame to fix this?
daven9113's Avatar
daven9113
Huffing, puffing sound....like a locomotive has been described as a blown head gasket. That's what I hear also, but it's a quick walk around clip, and tough to zero in. Things can go south at any miles really.
Edit: You can replace head gasket and rocker gaskets while engine is in the frame. Something you can definitely do.
Old May 21, 2021 | 08:37 PM
Windseeker's Avatar
Windseeker
Is there anything else I can film/record to help anyone further diagnose? I know it's not the same as seeing it in the flesh, but would that help?
Also, if I were to decide to tackle the job, how long does it typically take? And, should I go ahead and do both heads?
Old May 21, 2021 | 08:59 PM
daven9113's Avatar
daven9113
Sure, a longer video may help. Get closer to the cylinders moving from front to rear, on both sides and don't go fast. Rev up the engine past idle It might eliminate somethings, but a true test would be a compression test to see the difference between two cylinders. Is there any oil coming out anywhere at the head gaskets?
If you are asking about the time it takes to do a head gasket replacement, 2-4 hours, and that's if you have all the tools and parts. Once you start a project, you never know what comes up though. Unless you are in a hurry, take all the time you need. Let's first figure out exactly what's going on.
If it's a head gasket, then just replace that one. No need to do both.
Old May 21, 2021 | 09:20 PM
Windseeker's Avatar
Windseeker
I'm seriously thinking about just taking it to a shop. Sure, it'll cost more but I also won't run the risk of hosing something.
I know that probably sounds lame to you guys, but my time is also worth something.
What does this job usually cost, just a ballpark?
Old May 21, 2021 | 10:17 PM
daven9113's Avatar
daven9113
No judgement here. Nothing wrong with supporting your local Indy. Ask around for a respected shop where you are located, and I'm sure you would be set. You can help out the next guy by letting us know what the issue was. Good luck.
