Help
Old May 29, 2021 | 06:03 PM
Shelleyfried's Avatar
Shelleyfried
Default Help
Put in a new starter, now it won’t stop engaging! Had to disconnect battery but if we try to reconnect battery it just keeps engaging, won’t stop spinning. 93 fatboy
Old May 29, 2021 | 07:51 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Was the starter you installed factory or aftermarket?
Old May 29, 2021 | 08:03 PM
mike131's Avatar
mike131
Year and modal of bike? Make sure battery is fully charged, make sure the wires are connected correctly on starter and not touching each other, test to make sure you only have power on small starter wire when starter button is pushed
Old May 29, 2021 | 08:23 PM
Shelleyfried
thanks for the reply! I actually took the selanoid apart and it was stuck. I sanded the copper washer down, put it back together and now it works. 😁
Old May 29, 2021 | 08:33 PM
mike131's Avatar
mike131
That will do it, Good deal glad you got her fixed!
Old May 29, 2021 | 08:35 PM
Shelleyfried
thanks man. Me, too. This bike has been a pain but she’s getting there! 😁😊
Old May 29, 2021 | 08:41 PM
mike131's Avatar
mike131
Yeah most of them can! thats why I call them females lol, but in your case the bike would probably be a male!
Old May 29, 2021 | 09:32 PM
Shelleyfried
😂 nah, she’s still a girl. 🤣
Old May 30, 2021 | 09:11 AM
Shelleyfried
All *****
Old May 30, 2021 | 04:14 PM
daven9113's Avatar
daven9113
That's real strange that your new All ***** starter would already have worn down solenoid contacts. I would keep an eye on that, especially if it's still under warranty. I've had start run-on before and it's not fun. I thought it was a weak battery, but in the end it was the solenoid internals, not he contacts. My solenoid went bad, and changing out contacts and plunger didn't fix the issue. That's why you should keep any eye on that, because you don't want to fix the symptom and still have the problem. Good luck.
