Feedback on EV46 vs EV27
Old Jun 23, 2021 | 11:02 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I'm not sure that Wiseco makes a 9.5:1 piston.. I know they make the stockers at 8.5:1 and then 10.0:1, 10.5:1and 11.0:1 compression pistons. If you're running nine and a half to one compression did you have Screaming Eagle heads put on or something with the flat tops? Anyways if you do a compression test at 9.5:1 compression with that ev27 cam in there you should have somewhere around 180 psi cold cranking pressure (CCP) the reason why I'm saying this is, I'm wonder if maybe the cam is off a tooth and one way to tell whether it is or is not is by taking a compression test But That's only relevant to the parts in the motor if your exactly sure.. And That's something you can do without getting into anything that the indy/shop did for you.. Can you do a compression test? The reason I'm saying all this is because with those upgrades it should be a very noticable difference throughout the entire rpm range up to at least 5500 rpm if not 6000 ..
Old Jun 23, 2021 | 03:09 PM
TheVanillaThrilla's Avatar
TheVanillaThrilla
Same cam, and I’m pulling to almost 5k. Torque dip due to 2-2 Big Radius exhaust, jetted but otherwise stock carb, pistons and ignition.
runto77
Engine Mechanical Topics
24
Feb 3, 2015 04:54 PM
Blue SOG
EVO
14
Jul 21, 2014 04:55 PM
jlasoftail
Exhaust System Topics
May 27, 2012 09:01 AM
jlasoftail
May 26, 2012 02:27 PM
venturaoutfit
Mar 27, 2011 09:35 AM
