Went to start my 98 Fatboy a few minutes ago, turned on the switch, pressed the starter button, a click down below somewhere and then nothing.
No lights, no horn, no nuthin. My test meter says the battery has 12.6 volts. I checked battery cables they're tight. Tested the 4 fuses they're not blown.
Any ideas?
solenoid and/or battery ... IIRC 12.6v is on the low side of being charged ... and it's not how much voltage you have on a sitting battery, it's about how much voltage you have when the button is pushed ... dropping below 11v is not enough to start the bike
I had problems with my FLSTC Ignition Switch.
When switching on, nothing worked.
Had to take it apart and clean out old grease and gunk.
Put it together again and everything worked again.
