Stock pushrods will be fine.
The only time you need to use adjustables is when you have a high lift cam.
In other words the only thing that affects pushrods is your cam choice.
The nice thing about the SE heads is that it will bump up the compression and do flow a little better than stock.. Make sure you replace the cylinder base gaskets and use a .030" head gasket.. Should be a fun ride..
