07-17 exhaust compatibility with evo question
Old Jul 28, 2021 | 03:32 PM
EFELESTEEN's Avatar
EFELESTEEN
Default 07-17 exhaust compatibility with evo question
i heard that 07-17 exhausts (specifically samson/bassani fishtails) were in fact compatible with evo era bikes. the only mods that need to be done are to plug the o2 bung and to drill/tap a spot on the frame to accommodate the exhaust bracket. anyone do this or heard this to be true?
Old Jul 28, 2021 | 03:39 PM
smitty901's Avatar
smitty901
Unlikely the header pipes would be. EVO and twincam a lot different.
Only one that can tell you for sure would be the manufacture. I need a rear CYL section of the the header pipe for mine. Looked for a year. Ended up having it welded.
Also if you ever need the tail light HD stopped making them but you can get aftermarket copies.
The HD Service manual covers 1995 and 1996 in the same book.
Old Jul 28, 2021 | 04:17 PM
Dr.Hess's Avatar
Dr.Hess
Complete exausts up to 07, if I recall, will bolt onto an evo. I have a 07 FLHT complete exhaust on my 86. The fit was perfect. I think I had to trim one bracket some for a tighter fit and add the sensor plugs. The ones that go under the frame, which I think started in 08, may or may not work.
Old Jul 28, 2021 | 04:27 PM
WP50's Avatar
WP50
I put D&D fatcat 2-1 from a 06 Road King on a 97 EG
Oh I did have to get a different mount at the trans other than that it was easy
WP
Old Jul 28, 2021 | 05:07 PM
Schex's Avatar
Schex
Up to '08 will fit.
A quick check on ebay showed at least 5 sets, here's one that's even wideband ready, $200 and 37 shipping
Old Jul 29, 2021 | 07:42 AM
EVOrider's Avatar
EVOrider
Up to 2008 fit just fine…..
2009 up with the ones going under….that’s a different story. We put that style on a 1997 Ultra. The headers bolted right on, had to modify the bracket that mounts to the transmission. Didn’t like it afterwards and returned it back to stock. It made it a real PITA remove the transmission dipstick and the left would make contact with the road on sharp curves. Couldn’t have the center stand and newer style exhaust…..he found the center stand more beneficial.
Old Jul 29, 2021 | 01:03 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Depends on the model bike you have.. A Softail will fit 86-2011...
Old Jul 29, 2021 | 01:56 PM
EVOrider's Avatar
EVOrider
I think he’s talking about the Softail….since there’s a Softail in his profile.
Old Jul 29, 2021 | 07:08 PM
mplecha's Avatar
mplecha
I'd recommend no drilling and tapping of the frame.
Old Jul 29, 2021 | 07:25 PM
EFELESTEEN's Avatar
EFELESTEEN
quick update: i ended up picking up a set of cobra tru dual fishtails. according the manufacturers notes “pre-96 models will have to drill and tap holes on the left side for the mounting bracket”
