I have no power. No lights, horn, ignition, nothin. New battery. Got bike from cousin hen thought it just needed battery. Need some help as im not familiar with this bike.
What bike is it? Check the main breaker, probably under the seat, but WHAT BIKE IS IT? Also, check the ground wire. Check the voltage between the battery + and the engine block with your volt meter.
1993 heritage classic. Battery cables are seem good no corrosion
