Hey everyone. I have a 1997 Fatboy with Edelbrock heads, mikuni carbs and a bunch of other go fast stuff. It has a restrictive exhaust that I will be replacing in the spring but for now, its fouling the plugs (front one as normal is worst). It has Champion RN12YC plugs in it now, can anyone recommend a 1 step hotter plug that will work? I think its RN14YC but before I do anything I figured I'd get some input from folks that know what they are doing. Thanks in advance.
I agree with posts 2 and 3. With these high output ignitions, fouling a plug to the point of causing a misfire indicates something else wrong - like excessive oil use or carburetor issues.
I'm sure its a carb issue. I need to get a less restrictive exhaust and set the carb correctly, which I plan on doing in the spring. I was trying to get a good temp solution for a few thousand miles until I do the real work.
i think you are doing yourself and your engine a disservice following this approach
An hours time and minimal $`s could probably correct this problem
HAHA! You guys might talk me into trying to adjust it. Carbs are not like regular wrenching for me because they aren't "binary" - they are sort of like art.
