Basket case
Old Oct 2, 2021 | 02:22 PM
Mountainkowboy's Avatar
Mountainkowboy
Originally Posted by PeterB
If you take that slightly used bike and pull every single nut and bolt apart on it, right down to pulling the weights out of the auto advance unit, the gears out of the gear box, the tiny little screws out of every electrical panel and swithc, split the crank into 5 pieces, and even take the the spring off the kick stand, then mix all the parts up in baskets and cans and milk crates so some crank parts are in with the rear brake parts, which have been stripped down to the pads and pistons bare, and the other crank parts in with the front fender mounting hardware, and make sure the heavy items are dumped in the top of each basket and the easily dented aluminum and sheet metal items are in the bottom. then throw away at least 25 per cent of the boxes of parts, and then add in some boxes of random washing machine parts, lawnmower parts and stereo speaker innards, THEN you have a basket case.
The one in your pic appears to have made a good start by sitting out in the rain for a good year with the electrics exposed and gas tap on before the serious basketing begins. Extra points if the plugs and oil filler cap are missing.
Slightly used 109K maybe 209K is not slightly used, and It wasn't sitting in the rain. He washed it off with a hose, and although it was not in boxes....it was still a basket case. Where it went to.................
What you describe in a parts stash.
Old Oct 2, 2021 | 04:40 PM
0maha's Avatar
0maha
I hope this turns into a "my basket case was more basket casey than your basket case" thread.
Looking forward to the pix.
Old Oct 2, 2021 | 09:10 PM
PeterB's Avatar
PeterB
No. To qualify as a parts stash, there must be at least 6 carburettors, all either missing the float or the jets or with a busted floatbowl casting, plus at least 6 magnetos, none of which spark, three transmissions with four speeds between them all, 10 dented gas tanks, a box of cracked headlight lenses, 25 totally flogged out pistons with rings stuck in grooves, two pairs of con-rods coloured all blue around the bottom half, two dozen used spark plugs all carboned up or burnt beyond recognition, and about 10,000 metal brackets whose original purpose is known to nobody on the planet. Usually advertized as "all came off good running bikes".
And 209,000 miles? An Evo is only just run in at that.
Old Oct 2, 2021 | 09:40 PM
Tcrafty's Avatar
Tcrafty
Originally Posted by Caper4Life
Cars are cheaper, but not by much. My truck and jeep are about $100/month each. Anything over 400cc here in Saskatchewan costs a small fortune to ride.
For clarification, is this simply to hold the plate, or does this also include insurance, etc? Trying to understand the thought process above the border, not pickin' or anything. Down here, we have plate fees, and insurance, which adds up. Just wondering if we look at what all is covered, we may find things done differently, but very similar in effect. Can you clarify?
Old Oct 4, 2021 | 09:27 AM
Caper4Life's Avatar
Caper4Life
6th Gear
This province has a government run insurance, where the plate registration and insurance are rolled into a single entity. The other provinces are separate, pay your registration then shop around for the best insurance rate.
Old Oct 4, 2021 | 10:01 AM
eighteight's Avatar
eighteight
Glad both myself and bike are old
12 months of full coverage insurance and plates = $230 USD
Old Oct 8, 2021 | 12:08 PM
Cruisin1966's Avatar
Cruisin1966
Correct, not like that here in the province to the west of you. License plate yearly renewal around here is $70 per bike and about $90 per car/truck. I pay about $500/yr insurance on my 1999 FLSTS for basic coverage, and about $800/yr each for the other two. Lets not talk about the insurance on the Ram 1500 after all the hail claims (province-wide) over the last couple of years
Old Nov 2, 2021 | 05:04 PM
Caper4Life's Avatar
Caper4Life
6th Gear
I was hoping to get a couple of more weeks of riding in before the snow starts to fly around here.... Something I forgot to mention in the list of issues this "roadworthy" (lol) bike has, is the seeping front base gasket, which I was hoping to address over the winter. What I thought was a leaky header gasket as well, is actually a blown head gasket on the rear cylinder. Time for an immediate tear down! I was pleasantly surprised to find adjustable push rods and what looks like aftermarket pistons, as they have a black coating on the skirts, so the engine might have been freshened up at one time. Luckily, there's no scoring on the head or cylinder gasket surfaces. I've already installed the Barnett CF clutch and heavy duty diaphragm, so much better now. Apparently, when the PO had the primary rebuilt, they didn't install the clutch pack properly, and left out one of the steels. No wonder I couldn't get the diaphragm adjusted to spec! I am going to inspect the lifters and the cam bearings while I have it apart as well, and install the braided steel front brake lines and auto turn signal module while she's off the road. My gasket kit and shifter shaft should be here in a few days. Any way, here's some pics from Sunday...
Edit: Forgot to mention I picked up a (puts on flame retardant suit) knockoff carb for it as well, and was actually pretty impressed with the overall finish of it. I tore it down and installed the Harley parts from my original though. People looking to get $300 for a used CV carb around here! NUTS! I can get an HSR42 for just over $400, which will be ordered for spring installation.
Old Nov 2, 2021 | 07:57 PM
Racepres's Avatar
Racepres
It ran and drove.......not a basket case.
This is a basket case
Nope... No Basket there...
Originally Posted by Dr.Hess
That's not a basket case. That's a "project bike." I've bought basket cases. They come in... baskets, trash cans, boxes, bags, etc.
Yup... Terminology is Important
Yup... But... Buying a Sorry Motorcycle, then Tearing it apart is Not Buying a Basket Case..That is Creating a Basket case... it is What you do with it that Determines your "Status"
But... Saving a "Sad Case" is sometimes More rewarding!!!
How my shovel started life, a bare frame and bunch of dirty crates & boxes at a swap meet, not all of them came for the same seller
BTDT
On an Evo just Now... kinda like this XL we acquired a few years back...
http://www.amraonline.com/BikePics/SportyBskt.jpg
Old Nov 3, 2021 | 01:00 PM
Caper4Life's Avatar
Caper4Life
6th Gear
Basket case was probably a harsh term to use.. I was more P/O'd than anything I guess, with the fact that "All the major stuff was done", when in fact hardly anything was actually done to keep the bike kept up to a ride-able condition, other than short trips around the neighbourhood. She's getting lots of love and care now though. I'm not letting it taint my first Harley experience!
