CV Carb Idle Setup question
Old Oct 4, 2021 | 04:57 PM
Jpcl's Avatar
Jpcl
Originally Posted by mike131
If there is no change in idle when adjusting the idle mixture, I would normally say the slow jet is to large, but you have 45, so thats good, there could be something wrong with the idle mixture jet it self or its packing, turning the idle mixture screw in should cut off the fuel at idle so the carb might be allowing fuel in from an other placed it shouldn't be
Yes agreed - its a little baffling. Will start out clean as was suggested above and see where that lands. Will set idle mix screw to 3.5 turn and then adjust the idle air screw to idle at about 800 rpm and then adjust the idle mix screw. If it doesnt have any effect then have to look elsewhere.
Old Oct 4, 2021 | 06:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t get your terminology mixed up...It makes it difficult to follow what you are talking about.
The idle screw sets the throttle plate position.
The idle mixture screw sets the mixture.
Old Oct 4, 2021 | 07:28 PM
mike131's Avatar
mike131
Let us know how it works out for you
Old Oct 18, 2021 | 09:05 AM
Jpcl's Avatar
Jpcl
Sorry it took a while to get to this but i managed to get it dialed in over the weekend, using the procedure described. Thanks for all the help..
Old Oct 18, 2021 | 09:51 AM
mike131's Avatar
mike131
Good deal, thanks for letting us know
Old Oct 25, 2021 | 04:56 AM
mplecha's Avatar
mplecha
what did you end up with?
reservoir dog
EVO
Nov 9, 2013 01:38 PM
Nuday
May 3, 2013 07:24 PM
nwpwr22
Ironhead
May 30, 2012 03:15 PM
dirty78ironhead
Ironhead
Apr 3, 2011 05:25 PM
redrum
May 31, 2008 12:19 AM
