Tapered roller bearing endplay
Old Oct 24, 2021 | 05:03 AM
twowheelin's Avatar
twowheelin
Default Tapered roller bearing endplay
Setting up my tapered roller bearings on my 94 wide glide and ive come to a point where i would only be running the top hat/spacer washer,and a .004 shim. Is this normal practice? as it seems pretty darn thin to be running alone. I feel like maybe i should have the spacer cut back .032 and add a heavier .032 shim to accommodate. Any input would be appreciated. Thanks
Old Oct 24, 2021 | 05:11 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Makes no difference the thickness. End play is correct your good to go.
Old Oct 24, 2021 | 06:02 AM
twowheelin's Avatar
twowheelin
Cool beans! Thanks again!
Old Oct 25, 2021 | 08:51 AM
Dehammer's Avatar
Dehammer
I had a paper thin shim on my RK that disentegrated. I keep a shim kit around so it wasn't a big deal. Not a mechanic so my experience is with what I have.
Before my next tire change I'm gonna order some DOM tube and machine the spacers down perfect so no shims required.
I looked online but I couldn't find anyone selling oversized trim to size spacers.
Old Oct 25, 2021 | 07:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There is no movement between the shim and the parts it comes in contact with, how would it disintegrate?
67Shuv
Aug 25, 2021 04:24 PM
KrzyCollan
Wheels/Tires
Apr 22, 2019 09:39 PM
Wasta81
Jun 19, 2017 12:49 PM
Vuoso86
Mar 27, 2015 05:20 PM
davidwideglide06
Jan 8, 2008 01:46 PM
