fork extension help .. 1995 evo
Old Nov 2, 2021 | 06:53 AM
misfitJason's Avatar
misfitJason
Can you elaborate a little.. I thought you had to change the fork tubes.. Will longer dampers work with the stock tubes? I didn't even know they made longer dampers.. This is a new and different approach that I know nothing about...
They make +2 dampers for 39mm and 49mm forks. It raises up the length of the forks as it goes into the slider providing a higher ride height.
Old Nov 2, 2021 | 07:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Never new there was such a thing.. thanks..
Old Nov 2, 2021 | 11:05 AM
misfitJason
I don't know if it reduces travel, but I have built a couple of dual disc 49mm Dyna front ends utilizing Vrod lower legs, and those are a necessity for the conversion. Works out pretty damn good
mtnman3
Feb 6, 2012 10:55 PM
