My stereo loses its memory on some start ups, I know, I know, I don't need a radio, but it's frustrating! Checked my grounds, battery connections and gave each a extra nudge, so anyone familiar with what I should look for? 1989 flhtc
Orig starter.
Where you have the memory wire for the radio wired in ck what the voltage is while cranking.
It's probably dropping to much. I'd wanna see it maintain no less than 9-10 volts
Any other symptoms when it happens??
Fires up as always...I'm thinking it's in stereo as it only started doin this recently,thanks for input.
QUOTE=WP50;20338428]Where you have the memory wire for the radio wired in ck what the voltage is while cranking.
