Rear brake sticking
Old Dec 22, 2021 | 09:52 AM
stav's Avatar
stav
Thank you all for your immediate responses, will try to fix it next week and update
Old Dec 22, 2021 | 03:28 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Racepres
I would Say!!! I('m wondering just How folks get a rear Wheel Off/On, without removing the Caliper First???? Maybe I'm just Uncoordinated???
Sorry Racepres, "I respect you" but I do it all the time.. it's a little fenagling but totally doable.. Merry Christmas Brother...
Old Dec 22, 2021 | 03:47 PM
strych9's Avatar
strych9
I quick way to determine if it's an upstream hydraulic issue (lines, MC) is to get the brakes to hang, then crack the bleeder open on the caliper and see if the brakes released. If so, you could have an internally collapsed rubber brake line, or master cylinder/plunger issue. If it doesn't release, your issue is at the caliper.
Old Dec 22, 2021 | 04:36 PM
t150vej's Avatar
t150vej
Originally Posted by stav
Thanks, will do that. If that doenst work i guess i need to rebuild the caliper. Would that require to take out the rear wheel?
No. You actually need the wheel on there when setting it all up. Pay close attention to the shims and the part of the caliper mount where the pads sit. If the shims are worn, things don't work well and if left unattended can wear and break the caliper mount where the shoes ride. (plus all the other good tips you've received)
Depends on the year and model, Touring, Dyna or Softail. Getting the wheel off is no problem but the rotor bolts are so close to the caliper mount on most of them, it will most often save time to pull the caliper and pads before going back on, even if it's a pre-'93 Touring that requires removing the muffler hanger, rear crash bar/battery box. Why would anyone work back there without doing a brake/caliper/mount inspection and pin lube?
Old Dec 22, 2021 | 05:17 PM
SirHarley's Avatar
SirHarley
Cool
Just keep in mind that in the extreme rare cases a bad brake line can be the problem. I dont think that's your problem because the caliper releases when the old brake pads are installed. To me, that suggests that the caliper has a rough spot, or the piston is pitted. A rebuild should do it. Also consider your rotor runout. Your bike is an antique now, so anything is possible. Old parts just wear out from old age sometimes. When this is fixed, remember to change out your brake fluid every other year or so. Moisture builds up in old brake fluid. It will help avoid a lot of issues.
Old Dec 22, 2021 | 10:29 PM
stav's Avatar
stav
Would the rotor runout cause the new pads to stick?
Old Dec 23, 2021 | 08:40 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Maybe the new pads are defective....
Old Dec 23, 2021 | 08:43 AM
WP50's Avatar
WP50
Not very likely.
When going together make sure the rotor is running in the center of the bracket
WP
Old Dec 23, 2021 | 12:56 PM
SirHarley's Avatar
SirHarley
Cool
A warped rotor can cause a caliper to overheat and stick. Ask me how I know sometime...
Old Dec 23, 2021 | 01:09 PM
stav's Avatar
stav
I guess i have to check and change the rear rotor as well. I have one brand new from an evo softail, not sure if it fits the electra though...
