starter problem
Old Aug 12, 2007 | 03:53 AM
juaniosa's Avatar
juaniosa
Default starter problem
hello ,
i got a starter problem it whins when i try to start it . How do i get the starter off its a 84 evo with a 4 speed tranny w/kickstart
Old Aug 20, 2007 | 11:34 PM
doberman's Avatar
doberman
6th Gear
Default RE: starter problem
I've got an 85' softail that does the same thing!
Old Aug 21, 2007 | 12:01 PM
Night_Train01's Avatar
Night_Train01
There are two short bolts holding the starter in place.....there will also be a big metal gasket. The starter you will want is an Hitachi style.
Old Aug 21, 2007 | 01:34 PM
pjb's Avatar
pjb
you may just need the starter drive gear. if the starter spins, but doesn't engage the clutch basket, check (replace) the starter drive gear.
Old Aug 21, 2007 | 07:21 PM
juaniosa's Avatar
juaniosa
Thanks for info bros . I took the starter off , starter gear tip of armature grinded worn out but gear that turns the clutch bbasket was good
Bob Onit
Jun 20, 2019 10:45 AM
littlemanCeaser1950
Shovelhead
Jul 22, 2017 01:16 PM
Rooster59
Aug 17, 2015 06:00 AM
Work0rDie
May 20, 2008 10:58 PM
bob
Mar 27, 2005 02:09 AM
