Evo cam position sensor...
Are you running a VOES? If so, you can tweak that so advance kicks in later or sooner as well.
Seems to me I heard the same numbers that t150vej mentioned. So what is the bottom line on how many degrees per line on the cam sensor?
No, not running a VOES at the current time.. But I was thinking of putting in a toggle switch to ground for the VOES wire like I did on my Shovel.. It worked very well... This way on really hot days or super heaven traffic, I didn't have to worry about detonation..
Here's my calculation for the timing increments.. I would rather use the cps to calculate because it has a larger diameter then the rotor cup.. Plus it has the marks on it..
So based on the one to two ratio then every one degree of cam timing should be 2° of Crank timing. So technically if we move 5° on the cam we're actually moving 10° of crank shaft timing....
I like motor oil too, it works well...
And your welcome.. Sir.....
I read all posts and now I got a headache.
And it's to early for beer Thanks guys LOL
WP
So yes, definitely 5 degrees from long line to long line, verified with a light. If you notice, the lines are tighter toward the center. It's easier to "guess" looking thru the slot and eyeballing off a trigger window on the rotor.
Hotrod, I know exactly what you're trying to do with the switched curves and advancing sensor past base static 35 degree setting. I've done it on mine before (for different reasons). Personally, I'd use a dial back light set on 35, with the module set to curve #3 and time it to TDC mark. That'd put curve 3 at 35 total and curve 4 at 33 total. You just couldn't run it on 1 or 2 without being way too high. I trust the flash over what I might measure with a caliper but that's just me. We all have our methods and I'm big on "whatever works for ya"
Don't they sell Goody powders out there yet. I had them sent to me from here when I was working around Odessa in the '80's. Every place of business I ever went in back then, there was a small fridge full of beer for employees. So I figure if you're in West Texas and you're awake, it's not to early for a kol-beer
Well the beer frig is concealed a bit more nowadays.
A dial timing light Jeeeez I'll grab a beer and go see if I still have mine. It's been a long time
WP
