Considering a cam swap
Old Apr 22, 2022 | 05:04 PM
sweatin_dad's Avatar
sweatin_dad
6th Gear
Default Considering a cam swap
I have a 94 fxr with ev27, ultima ignition, wiseco 10:1, thunderheader and hsr42. My bike runs great, but I have issues with hot starts and some pinging. I understand what a cam does and how, but my knowledge of them is pretty basic. I understand the ev27 isn’t so great with higher compression.
Is there a cam that would better fit what I have? I’ve been considering a woods w6. Would that be worth the swap or too similar? I typically ride solo and like to go fast. The ev27 fits my riding pretty well, but I’m willing to make changes.
Old Apr 22, 2022 | 07:40 PM
86glider's Avatar
86glider
I’ve got an ev13 in mine with similar setup which has nice pull right from idle.I use premium gas and the Ultima (recently swapped to a Dynatek) was set at #3 curve. Didn’t have a pinging problem.Did you static time it by way of the instructions?
Old Apr 22, 2022 | 09:20 PM
sweatin_dad
6th Gear
I did. It doesn’t ping all the time. I’m more concerned about the hard starts.
Old Apr 22, 2022 | 10:12 PM
Tommy C's Avatar
Tommy C
A 1.4KW starter will take care of the hard starts or you can have compression releases installed in the cylinder heads.
Old Apr 22, 2022 | 11:41 PM
sweatin_dad
6th Gear
My fatboy has compression releases. I’d prefer not to have them in the fxr. I’ll keep that starter in mind.
Old Apr 23, 2022 | 12:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
One way to help the hard start is just by going to a longer duration cam with an earlier n later intake close.. it makes a huge difference..
Old Apr 23, 2022 | 12:50 PM
sweatin_dad
6th Gear
I’ll have to get back to you on ccp. My heads are stock. Everything was rebuilt about 10k miles ago, but it’s all stock.
Old Apr 23, 2022 | 01:05 PM
98hotrodfatboy
The crane H296 is a very good bolt in and won't be too soft under 3k because your static comp if it is indeed indeed 10:1..
Old Apr 24, 2022 | 07:06 AM
98hotrodfatboy
Sorry I made a mistake.. The H286 is a bolt in cam for stock heads. the 296 requires head work..
Also test your VOES switch for the pinging issue..
One more thing, the Ultima ignitions curves are very fast ramping you might be better off with a Dynatek 2ki ignition..
Old Apr 24, 2022 | 09:45 AM
t150vej's Avatar
t150vej
Most say an EV27 needs more than stock compression but who knows?...
When you say hard starting, do you mean difficult for the starter to turn it over, or turns over too long before starting? (or both) Hows the fuel mileage and did you install the Mikuni or someone else?
The 2nd questions may sound irrelevant, but I have some ideas that are or may be. But need to know those 2 answers.
** make that 3 questions. When does it spark knock (ping)? Under hard acceleration or on mild acceleration?
