Blown Headgasket
Old Jun 7, 2022 | 11:01 PM
Schex's Avatar
Schex
I spray lightly just enough to cover and let it dry, no heavy coat. The heads are stuck good when you go to take it apart.
Old Jun 8, 2022 | 02:07 PM
IBDAGRIZ's Avatar
IBDAGRIZ
I was and am an Indian Head Shellac guy on base gaskets. Copper coat on the copper head gaskets on the shovel too.
Griz
Old Jun 8, 2022 | 07:07 PM
98hotrodfatboy's Avatar
98hotrodfatboy
On a brand new MLS gasket I wouldn't use anything. And I would stay away from the graphite gaskets, seriously. And when it comes to torquing, make sure you put oil on the studs so you got a good torque sequence on the head bolts.. At this point I would definitely do both heads...COMETIC .030"....
Old Jun 8, 2022 | 08:14 PM
Captscotty's Avatar
Captscotty
Thanks much 98hotrodfatboy and all you dudes
Old Jun 8, 2022 | 08:40 PM
Captscotty's Avatar
Captscotty
Originally Posted by 98hotrodfatboy;[url=tel:20655270
20655270[/url]] At this point I would definitely do both heads...COMETIC .030"....
One thing though…S&S headgasket is .045 and you recommend the Cometic .030. Are there considerations for a change like this? Why recommend the .030? Stronger??
Old Jun 8, 2022 | 08:55 PM
98hotrodfatboy
Honestly, it'll depend on your current static compression and what the cam intake valve close timing is. Me, I've always only used .030" head gasket in all my builds. It helps to reduce the squish which can actually help in preventing detonation.. It will increase the compression but that's not a bad thing.. Did you ever do a compression test with what you currently have?
Old Jun 8, 2022 | 10:27 PM
Schex's Avatar
Schex
You have to check the piston deck height, then add head gasket thickness to determine squish clearance,.030" squish clearance is about the tightest you should go for street use.
What pistons are those, I thought they were cut for angled combustion chambers, but looking again, no?
Old Jun 9, 2022 | 06:41 AM
Yankee Dog's Avatar
Yankee Dog
In addition to putting a drop or two of oil on the stud threads, put a little oil on the underside of the flange of the head bolt (actually a nut but what ever) where it contacts the cylinder head.
Old Jun 9, 2022 | 08:55 AM
Captscotty's Avatar
Captscotty
Pistons are S&S special order to size correctly after machining the jugs and heads. Eric Nichols, AMS Moto in Cleburne is one of our legit shops in DFW metroplex. Ill text him this morning regarding HG thickness for my application.
No compression test yet because I built up the motor, not Eric. I’m sure he would have done one.
Purdy when they’re new, eh??
Old Jun 9, 2022 | 09:04 AM
98hotrodfatboy
If you can get all the specs on the build it would be nice.. Also what cam is in it? Any porting on the heads?
