Compufire 3 charging system replacement questions
I didn't think pulling the rotor of any of the FL short primary models was an issue and the photos from the OP aren't enough to convince me otherwise. But, he's there, I'm not
And, did I read the instructions correctly - the wires coming off the stator don't need to be plugged into the vr in a specific way? They have no polarity?
And, the original vr wires went to the main breaker and a common ground in front of the battery. The instructions say to run the new wires directly to the battery. Does this matter?
If the ground connections are optimum shouldn't matter on the negative. The original main breaker is 50 amps and it may not carry the alt current at full output. 100+ amp car charging systems go to directly to the battery or via starter cable connections. I suppose it may generate debate but I'd just follow the instructions and go to the battery.
Regardless, not trying to spook you, just take a look at it and make sure nothing is amiss. Again, I would hate to see you have to go back in after all back together.
Oil inside the pulley (orange scribble) is usually from the IPB seal or the 5th gear mainshaft seal (red arrow). As mentioned, the 5th gear mainshaft seal can be wiped out by the inner primary bearing inner race walking into it over time (the race is pressed onto the shaft). Should be a .100 to .125 inch clearance between the race and the edge of the threaded portion of the 5th gear (the part the nut threads on to) for proper positioning for the bearing and to get the race removal tool on.
Oil leaks behind the pulley are usually from the large spacer seal (the spacer is behind the pulley) and or a quad seal that is a funny shaped large O-ring that sits behind the spacer. If it smells like oil most likely the IPB seal which I assume your replacing anyways.
If it smells like trans fluid (differential fluid) then it could be the mainshaft seal.
BTW, use electrical tape on those splines and threads when fitting the inner primary back on. The splines/threads will damage your new IPB seal if you don't. Also coat the tape with some oil or grease.
I got it all back together and it's running well! I think I need to adjust the clutch but it's quiet and charging like it should!!
so, the oil on the drive sprocket is actually from the last time I had this sucker apart over the winter (about 1000 miles ago) to replace the trans output seal which was leaking. It was a huge mess and what you see is residual. Also, the Allen bolts that hold that collar in place backed out and dug into the inner primary.
See here:
https://www.hdforums.com/forum/touri...questions.html
Crazy...
But, thank you all for the help. Hope to see you out on the road!
