1997 Electra glide issue
Old Jun 26, 2022 | 03:29 PM
Johnathan's Avatar
Johnathan
2nd Gear
Default 1997 Electra glide issue
My Electra glide ultra classic randomly dies it it had the magnetti marelli converted it to s&s super E due to the dying issues and erratic idle but still has random dying could this be temp sensor, or ignition I’m still running factory ignition
Old Jun 26, 2022 | 04:55 PM
im's Avatar
im
Since you converted to carb it would really require more information.
For example the CRANK position sensor connector located in triangle area of from under painted side cover by seat can get loose.
It is a push and turn connector.
When loose, it will cause bike to shut off over bumps.
Unfortunately very few techs check that ONE connector and push owners towards changing parts or carb instead.
Consider review of that ONE connector and place a zip tie on it.
Old Jun 26, 2022 | 05:18 PM
Johnathan's Avatar
Johnathan
2nd Gear
Removed the MM fuel injection installed brand new s&s super E kit cam with intake, and all I did was remove pin # 6 for engine light everything else is stock
Old Jun 26, 2022 | 05:27 PM
im's Avatar
im
Check the CRANK sensor connector.
Old Jun 26, 2022 | 06:57 PM
Johnathan's Avatar
Johnathan
2nd Gear
I checked the crank sensor plug and cleaned put back together still dies randomly while riding and then starts back up after a couple seconds and idles rough but runs if you let it sit idling for a few minutes it will be choppy then smooth out then back to choppy when it’s choppy the throttle is doggy but when smooth it’s real responsive it’s like it looses a cylinder every once and a while while it’s idling
Old Jun 26, 2022 | 08:29 PM
1997bagger's Avatar
1997bagger
Check the ignition module for being distorted from heat, they melt causing a random shut off and restart
Old Jun 26, 2022 | 10:43 PM
im's Avatar
im
Did you check connector or sensor by oil pump?
the connector gets loose and is under side cover about 12 inches from ecm
Old Jun 27, 2022 | 06:33 AM
flhchaz's Avatar
flhchaz
You may also wants to check the main circuit breaker, they get "funny" when they heat up, the are fine when the cool down
Old Jun 27, 2022 | 01:50 PM
IBDAGRIZ's Avatar
IBDAGRIZ
You converted from EFI to carb and used the stock EFI ignition harness and module?
Griz
Old Jun 28, 2022 | 09:25 PM
1997harleydresser's Avatar
1997harleydresser
6th Gear
https://www.vtwinfuelinjection.com/ I just converted my 97 and used this harness with a twin tek module. Never going back. Sounds like whatever problem you had with the MM came over with using it for ignition.
dfowler1
Motorcycles For Sale
Jul 17, 2017 09:17 AM
Primo
Touring Parts
Apr 30, 2015 03:11 PM
moparman1969
Oct 25, 2012 11:46 AM
gopoke
May 31, 2011 09:20 PM
brad klease
Jun 20, 2010 04:11 AM
