Yesterday I was cruising on the highway and suddenly lost power and realized that I lost all my electrical system, then stopped on the highway's shoulder and tried to reset everything by rotating the ignition switch to off and back to ignition/lights but it was stuck on lights, even being stuck I noticed that the switch was a bit loosen, it had more play than usual, even being locked on lights position i was able to force a little bit upwards to make electrical contact again, running again it lost electrical again sometimes due to vibrations but thankfully I already knew what was going on, just forcing the switch upwards a little bit did the job.
At home I was disassembling the switch from the support plate and magical it unlocked by itself, dunno what the freak happened but now it's "working" again but as I mentioned above it's loosen, so it doesn't offer resistance to switching like before so I don't wanna ride again without replacing or repairing it because I know it will cause electrical contact issues with vibrations.
Disassembled the entire switch and everything looked fine for me, It's cheap to replace but I would like to know if anybody experienced this, my switch is almost 30 years old and I suspect something is happening with the roller bar spring, maybe dislocated from it's original position, not sure, the spring is the only part I was unable to extract from the assemble.
No reason to run with key in the ignition. Keep it in your pocket and just use when you want to lock it. If you get stuck, just remove the switch entirely and then I think you could use a flat head screwdriver to rotate the bottom portion of the switch to run the bike or is that where the problem is. Some years of these bikes had an ignition recall, but I don't know the particulars what was involved. I know my bike still has an open ignition recall, but I've never had any problems and doubt 24 yrs later HD would fix it.
It's a softail so it's the rotating **** mounted on the tank, key is only used to lock or unlock.
I have my old switch off the bike, it just rotates well but it doesn't offer the same resistance than previously, already mounted a new one, I suspect something went wrong to the spring because it locked itself the day it failed for no reason, just riding, and after that it magical unlocked, now it's not like before anymore.
Well, it lasted almost 30 years, good stuff
This is why I carry a 12 gauge jumper wire with 2 male spade connectors for my Softail ignition.. They are prone to breaking due to the solid mount motor vibrations. If you do get stranded all you need is a 1/2" wrench to remove the dash nut and install the jumper and your back on your way.. Easy Peasey....
