New here
Old Sep 26, 2022 | 09:37 PM
1997bagger's Avatar
1997bagger
Originally Posted by k9kodi
Really, what tank do you think it is? I took the seat off tinkering today and saw that the rear of the tank is not secured to the frame and I’m trying to figure out what I need to secure it. It’s just resting on the frame.
good news though, new battery, and gas in a spray bottle and she fired right up and kept running so long as fuel was being sprayed into the carb. I started in on the carb and it is filthy and sticky with sludge. Pulled the carb off (s and s super e, and ordered a rebuild kit. First motorcycle carb rebuild, but not new to carbs at all.
You will need to drill a hole and tap it our put a insert in for the rear mount, the squared off OEM tank has 2 tabs on the frame for screws to mount it, if you lift the tank up you'll see tabs and unable to use them on the newer model tank you have.
Old Sep 27, 2022 | 06:25 PM
k9kodi's Avatar
k9kodi
I was thinking of drilling the frame and inserting two nutserts. What y’all think?
app JD foo
Apr 23, 2022 10:04 PM
dixieoutdoors
Jan 22, 2015 06:32 AM
story808
May 29, 2012 07:42 PM
warrick
Oct 13, 2011 12:03 PM
jeh83
Jun 3, 2011 08:09 PM
