1997 fatboy wheels
Old Oct 10, 2022 | 05:46 AM
seagullplayer's Avatar
seagullplayer
Default 1997 fatboy wheels
The previous owner changed out the OEM solid wheels for spoke. They don't look bad, but require tubes.
I would much rather run tubeless. I have seen claims you can make a spoke wheel tubeless.
Has anyone done this?
If I look for a tubeless wheel option, what years should fit my bike?
Thanks for any direction. There are a set of wheels off a 2000 road king local that look good, just not sure of fitment.
Old Oct 10, 2022 | 06:31 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The rim size is the same but the mount (center hole) for the rotor and pulley is larger.. You'll have to get 2000 up rotor and pulley..
Old Oct 15, 2022 | 09:24 AM
ChopperBill's Avatar
ChopperBill
On bicycles you can run some duct tap around wheel to seal the spokes and change the valve stem. Works for bicycles but I’d check that idea out with someone more qualified then me on a motorcycle
Old Oct 15, 2022 | 04:47 PM
Trumpet's Avatar
Trumpet
Man, if you were local we could try to work a trade. I've got solids and want spoked.
Ah well.
Old Oct 15, 2022 | 11:19 PM
Prot's Avatar
Prot
There are spoke wheels that are made to run tubeless and even then, they sometimes leak. I can’t imagine trying to convert a tube type spoke wheel to tubeless would be like.
I think you can probably get some fat boy wheels off of eBay and then recoup some of the cost by selling your wheels.
I don’t think going with newer road king wheels is worth the effort.
I remember TexasHillCountry converting his heritage to dual disk brakes up front years ago and it involved a road king wheel and forks but as simple as that sounded, it ended up being a lot more trouble than it seemed like it should have been and ultimately was not worth it even though he did get it done.
WillyShiny has a wheel exchange service where the chrome plate and in some cases machine wheels. They mostly work on an exchange basis but if you fail to return the core, they charge you $300 or something. If you can’t get fat boy wheels from the appropriate year, I think I would contact them about purchasing wheels outright.
Even though they aren’t cheap, for what you get and the quality of the work their pricing really isn’t bad at all.
I just did a quick search on eBay and found used OEM disc wheels for $259 each. That’s the easiest and cheapest way to go.
Bluffsguy
Aug 14, 2022 11:06 AM
FatKen
Dec 15, 2015 08:27 AM
steelerdude1
Oct 21, 2013 09:20 AM
mars636
Jan 13, 2012 04:12 PM
Legendary6301
Jul 31, 2006 08:03 PM
