Johnson Hylift Instructions ?
Old Jan 26, 2023 | 10:27 PM
johnod's Avatar
johnod
Default Johnson Hylift Instructions ?
Does anyone have the instructions for Johnson hylift lifters and adjustable push rods?
All I see online is for twin cams.
Thanks.
Old Jan 27, 2023 | 06:47 AM
johnjzjz's Avatar
johnjzjz
Depends on the thread count of the pushrods course is less turns then fine thread you did not ost what you bought
Old Jan 27, 2023 | 06:59 AM
johnod's Avatar
johnod
Previous owner bought push rods.
Old Jan 27, 2023 | 07:00 AM
misfitJason's Avatar
misfitJason
You need to figure out the thread pitch of the pushrods. No one can help you unless you know that.
Old Jan 27, 2023 | 07:08 AM
Yankee Dog's Avatar
Yankee Dog
As mentioned for the rods, as far as lifters, never install dry/without priming them first...ask me how I know...
Old Jan 27, 2023 | 08:39 AM
johnjzjz's Avatar
johnjzjz
Bring them to a machine shop they always have thread count gages - it takes a minuet to give you a number like 24 - 28 - 32 kind of thing
a photo is a guess to see it on line i believe in total 8 different threads were used it was never a standard use thing - reason you need to know exactly as it changes the location of the lifter
Old Jan 27, 2023 | 09:52 AM
johnod's Avatar
johnod
I'll check the thread count, have a gauge just for that.
Old Jan 30, 2023 | 09:50 PM
Scottyxbones's Avatar
Scottyxbones
Jumping on to this thread:
you could hold up a tape measure to the threads and count how many there are within one inch
i have additional questions: how do you test if lifters are good or stuck collapsed/pumped up?
The last time I tried rebuilding my top end with new hylift Johnson lifters and Andrew’s ez adjustable pushrods, I set the cylinder to just past tdc compression stroke (after intake closes), adjusted the pushrod up 24 flats (4 full turns) per instructions, waited 15 min and verified each one could spin by hand, as far as I know that’s all proper procedure. When I recently pulled the spark plugs my front was all crusted in white and the rear was dark, caked with soot and smelled like gas. Both cylinders exhaust valves were white (had a carb issue) but the difference in condition with the spark plugs leads me to think one of the cylinders (or both) had an issue where valves were not opening and/or closing correctly. What do y’all think?
Old Jan 31, 2023 | 07:27 AM
wfolarry's Avatar
wfolarry
That's a tuning problem not a lifter problem.
Old Feb 14, 2023 | 04:25 PM
johnod's Avatar
johnod
I pulled the push rods etc today, the thread count on the push rods is 25 tpi. So acn anyone let me know what/how the adjustment is?
There is no name on the push rods so there was no help there.
On a slightly different note, the inner cam bearing is a Koyo, seems fine, is there any point in replacing it, with a new Koyo, which i already have?
The lifters seem fine too, but I figure I'll replace those as i'm already in there and have the new lifters already.
