Finding neutral
Old Jun 16, 2023 | 08:01 AM
dirt rookie's Avatar
dirt rookie
Default Finding neutral
Reading through the owner's manual for a 1995. FLSTF, I noticed this:
I have probably owned 10 or 15 motorcycles in my life. I have never heard of this before.
Old Jun 16, 2023 | 08:52 AM
Fatboy1389's Avatar
Fatboy1389
It may be easier to put in neutral from 1st but you can definitely put into neutral from 2nd as well. Way back in December of 1994, I occasionally had difficulty finding neutral on my 95 but after a few short weeks of riding it wasn’t a problem….
Old Jun 16, 2023 | 09:05 AM
cycleman11's Avatar
cycleman11
Interesting. It is easier to go from first to neutral as you often go right by neutral into first if you are shifting down from 2nd gear. On the HD I've just gone down into first and up to neutral and can't really ever think of a time when I tried to find neutral from second. I'll have to try it.
Old Jun 16, 2023 | 09:09 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Apparently, you have never owned a 5-speed big twin with the early design shift drum...
I never had any reason to try to find neutral from second gear, when I come to a stop the transmission is in first gear.
Old Jun 18, 2023 | 07:25 AM
cycleman11's Avatar
cycleman11
I tried this on my 98 yesterday and it shfited fine from second into neutral at a stop. So maybe the later years transmissions where a bit different.
Old Jun 18, 2023 | 09:32 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The newer design shift drum came out on Softails in model year 2000.
The remaining models got the new shift drum in model year 2001.
Old Jun 18, 2023 | 10:46 AM
Rounders's Avatar
Rounders
Ap
I often coast into my parking spot in neutral. Not with an evo, but I do find it a common practice for me.
Some year evos also you could adjust this I believe.
Old Jun 18, 2023 | 10:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Old Jun 27, 2023 | 07:02 PM
zimm's Avatar
zimm
It would be nice when trying to get into neutral and it clicks into second instead. I found a quick blip of the throttle helps click into neutral.
Old Jun 27, 2023 | 07:07 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I have probably owned 10 or 15 motorcycles in my life. I have never heard of thirs before.
Still that way in 04 on my Softail. It will go but very easy to overshoot it.
It probably says that since it may first appear in neutral and jump to low. Sure would not want that to happen.
If you look at the cam plate, you will see why.
