Front brake light switch
Old Jul 28, 2023 | 05:42 PM
ShrinerRider's Avatar
ShrinerRider
Default Front brake light switch
Before I go any further on disassembly, with ignition on lights, activating the plunger should trigger the brake light, correct? My brake light isn’t working, and I am assuming it is the brake light switch since I messed with the hand controls before it went out. I am assuming the light is on all the time, which is why it appears to not be working. Does that one Phillips screw hold the switch in there? 89 FLT
Old Jul 28, 2023 | 05:55 PM
t150vej's Avatar
t150vej
Wrong. Pushing the switch plunger in should cause the brake light to go off. (it is a "normally closed" switch)
If you were "messing with it" before it started acting up, you possibly didn't have the spacing between the (pictured) housing and the master cylinder set correctly. Doesn't take much to change the behavior of the brake light. Move the switch housing closer to the m/c takes more lever travel to activate light. Further away less travel to activate.
Old Jul 28, 2023 | 06:21 PM
ShrinerRider
I agree with the spacing comment, but with it apart like this, then the light should go out if I push the plunger all the way in, and come on when I release it, correct? Maybe I worded my question wrong. I’m just trying to verify it is bad before I replace it.
Old Jul 28, 2023 | 06:26 PM
t150vej's Avatar
t150vej
No worries, I may have read it wrong
Correct. Pushing the brake light switch plunger in, should turn the light off.
Old Jul 28, 2023 | 06:38 PM
WP50's Avatar
WP50
If it doesn't you may wanna ck the foot light switch, easy to unplug as a rule to take it out of the equation.
WP
Old Jul 31, 2023 | 08:06 AM
ShrinerRider
WP
Funny you say that...
I replaced the front brake switch and now the stop light works, from the lever. I have nothing from the rear brake, so I am guessing
1) That switch is out also
2) It operates different and when it is out, the brake light does not come on, as opposed to the front which keeps it on all the time
Now I need to find the rear brake light switch, yes I have a manual.
Old Jul 31, 2023 | 08:15 AM
t150vej's Avatar
t150vej
I replaced the front brake switch and nor the stop light works, from the lever. I have nothing from the rear brake, so I am guessing
Rear brake switch is hydraulic. Lay down on the right side of the bike and look just inside the frame between the trans and engine. It'll be pointed inward. Has 3 wires - one is 12v + the other 2 tied together are the 12v feed from the front lever. The other one there goes on to the rear (light).
Old Jul 31, 2023 | 06:45 PM
ShrinerRider
Well that looks super easy to get to… switch is ordered.
Old Jul 31, 2023 | 11:23 PM
Spanners39's Avatar
Spanners39
99% of the time, you won't even need to re bleed the rear brake if you are quick and don't touch the lever when the switch is out. In 40 years I have never had to re bleed after a rear brake switch swap....doesn't mean everybody is that lucky though.
Old Aug 2, 2023 | 09:06 PM
ShrinerRider
I’m probably the 1%. I switched it out, quickly, without touching the lever, and now my pedal feels soft. We will see when I get it back together and ready to ride. Still waiting on a screw to get the front hand controls back together.
