86 FXRD carb issue
Old Oct 27, 2023 | 04:54 PM
Rick S's Avatar
Rick S
Default 86 FXRD carb issue
I’m fighting a stumble or something around 2k rpm’s. It feels like it gets a shot or two of water as it will stumble and fart around before clearing up. It has the original kihen butterfly carb which has been rebuilt and cleaned. I pulled the plugs after a highway run and they weee not gas fouled. I did shoot some carb cleaner into the air bleeds which seemed to help on the last ride. Any one got any ideas? Not interested in changing carbs.
Old Oct 27, 2023 | 06:57 PM
Y2K's Avatar
Y2K
Honestly I'd chitcan that carb and swap it to a CV 40,I did the swap on my '84 FXRS years ago with a carb off a 92 FXR and it not only run a lot better both cold and warm but it had better throttle response and even got better gas mileage.
My 2cts.
Old Oct 27, 2023 | 07:47 PM
Rick S's Avatar
Rick S
I like CV carbs and may have to do that over the winter. I’ll have to figure out exactly what needed to do the change. I hate to admit defeat so soon.
Old Oct 28, 2023 | 08:09 AM
Trumpet's Avatar
Trumpet
When's the last time the intake seals were changed? Other than that 2k rpm isn't really where you should be riding, things will smooth out over 2700rpms.
Old Oct 29, 2023 | 07:21 AM
t150vej's Avatar
t150vej
Check the accelerator pump, make sure it's squirting. Is the rubber plug in place over the low speed jet? (inside the bowl)
Old Oct 30, 2023 | 05:21 AM
mplecha's Avatar
mplecha
It’s not defeat. The cv is a far better carb.
Old Oct 30, 2023 | 09:52 AM
Racepres's Avatar
Racepres
Nothing wrong with a Stock Carb, If ya learn to Tune it..
t150vej has got ya started down a Good Road... Follow up!!
Even if the Acceleraror pump is the Very Last thing I concern myself with...It is an Excellent band aid for a Less than Perfect Tune..
PS... While carb is Off for cleaning...Is the idle jet screw exposed???
Old Nov 9, 2023 | 06:12 AM
Rains2much's Avatar
Rains2much
Hope you figure it out soon!
john lee
Shovelhead
Oct 23, 2023 12:13 PM
john lee
Classic
Oct 22, 2023 05:27 PM
Bruno2
Mar 2, 2009 08:29 AM
79Hogrider
Sep 21, 2007 06:33 AM
wob925
Ironhead
Sep 1, 2007 02:23 PM
