86 FLH issues
Old Nov 24, 2023 | 04:48 PM
flhchaz's Avatar
flhchaz
Originally Posted by Racepres
30 Amp...I'm betting!!!! But...Never had a Newer "Barge"
Could be a thirty amp.
Old Nov 24, 2023 | 05:56 PM
Onlydad's Avatar
Onlydad
Thanks for all the replies. I got to it today, Coil seems okay within spec as per manual. doesn't address re hot but trying to keep it budget here. Checked stator not running, seems okay as per manual, OL and 4.5 as I recall. checked Ignition module output as per manual seems ok, Carb was full of gas, squirts when I hit the throttle, petcock has no vac line so I figure it's not a fuel issue..
Emptied the fuel tank will buy some fresh gas.
I ordered a pickup. $ 80 CAD, be here Tues or so... Will report back
Dano.. I do want to get at the oil leak, seems I have a few days of waiting here so.. Question for you and for all is how do I remove the tubes covering the lifter rods? They're not stock, don't seem to untwist, I can pry them up for say 1/4 or 1/2" but that's all. Even if the rods are adjustable which I believe they are I cant get at em? Nt too big a job pulling the heads, especially now I have the tank off and coil out but I'd rather not If I don't have to. besides how would I set the adjustable rods if the covers aren't removable... Confused. Has anyone seen these type of rod covers?
Thanks again to all.
Cheers
Old Nov 25, 2023 | 08:04 AM
Racepres's Avatar
Racepres
I remember those pushrod tubes...but...gonna need to jog what is left of my memory...I would have bet they unscrew... looking..
Generally accompanied Adjustable pushrods...But, early on...adjustables did Not necessarily mean removeable...
Edit; Maybe someone knows how to Google images...I gots No Younger Folks handy just now!!!
Edit again...; Next time I'm in town I will encounter about an 8-12 year-old and have em do that with my Phone...
Old Nov 25, 2023 | 10:13 AM
johnjzjz's Avatar
johnjzjz
Yea they came with a rubber napkin so you could tighten the center thread
Old Nov 28, 2023 | 05:00 PM
Onlydad's Avatar
Onlydad
Got it running. Installed the new pickup, advanced the timing quite a bit, it runs. I'll go through the timing procedure tomorrow but it starts and stops and idled for ten min no problem. Gladly accept any advice on timimg but I think I have it clear enough.
Any more thoughts on the tubes will be appreciated, I have tried but apparently it will take a bit more muscle, don't want to break them just because I'm too lazy to pull the valve covers off.
Anyways, thanks to all for your input.
Cheers
SkyNet2112
Shovelhead
37
Jul 29, 2021 03:09 PM
rebelpiper
Jun 27, 2012 12:18 PM
Hedgehog1966
Shovelhead
14
Nov 3, 2009 10:28 AM
jeffc1507
Exhaust System Topics
Feb 18, 2008 03:37 PM
brokenbarrel1
Feb 10, 2007 04:20 PM
