kickstart only battery
Old Nov 29, 2023 | 03:26 AM
marcelm's Avatar
marcelm
Thank you all for the replies, your knowledge is realy helping me.
I want to do a lot of mods to my new (for me) `87 Softail, kickstarter only, open belt drive, new fuel & oil tank ... etc and give a much clean look of the bike, as possible.
I understood that for a kickstart only bike, a small 12V battery, maybe 4Ah, will run just fine with the stock alternator & regulator and with the Dyna S ignition.
Means, the stock regulator & alternator will not fry the small battery. I will have no extra electric stuff, just turn signals, headlight & tail light.
Thank you
Marcel
Old Nov 29, 2023 | 06:54 AM
t150vej's Avatar
t150vej
Thank you
Marcel
The battery will only accept the amperage it needs to come up to full charge regardless of it's, or the charging systems size.
That's a 22 amp system if it hasn't been changed. If a regulator fails, it could fry a diesel truck size battery given time, so just put that out of your mind. Headlamp, brake/tailight, dash lights will only amount to about 5 amps.
Old Nov 29, 2023 | 10:59 AM
Racepres's Avatar
Racepres
I've kicked over a 88" shovel with the dyna-s using two 9v transistor batteries in series when i left the key and killed the battery. Bike fired right up and ran fine on the charging system till battery came back up. If all you doing is using the battery as an exciter and lights when running find a small 12 volt lithium battery, factory charging system will work fine as is.
And yes the dyna-s makes all the difference in this case, stock or most other electronic ignitions have 1 or 2 dead revs before firing, the S doesn't.
Not the earlier ones.. certainly Not the Sportster systems I put on my Big Twins..zero dead revs...Stock
Not a Function of the Battery tho... a function of something called the Regulator
Saying a Battery will Not accept an Overcharge is misleading...Plenty (too Many) batteries have been destroyed (even blown up) by Overcharging...Unregulated Charging!!!
Old Nov 29, 2023 | 11:23 AM
t150vej's Avatar
t150vej
Agreed. I didn't have what I was saying in listed good order.
A failed regulator can cook and/or explode any battery with runaway voltage. And true, not the battery function per-say but a good battery with a properly operating regulator, as the volts come up, the amps go down. Doesn't matter how big the charge system or small the battery.
Old Nov 29, 2023 | 02:43 PM
marcelm's Avatar
marcelm
Clear then, if the stock regulator works fine, no matter how small (Ah) the battery is. My small battery will not explode ...
Thank you
Marcel
Old Dec 1, 2023 | 11:24 AM
08xl1200r's Avatar
08xl1200r
I'm a big fan of Odyssey batteries, the PC535/ODS-AGM16B in my kickstart only Norton lasted 12+ years. Various sizes are available, not cheap but reasonable considering the long life. The Odyssey page below shows some as sold out but they are available from dealers, Amazon, etc...
https://www.odysseybattery.com/store...rts-batteries/
DaleMc0622
Mar 7, 2018 10:02 AM
JPD17
May 15, 2017 07:00 AM
Fatsacz
Electrical/Lighting/Alarm
Feb 8, 2017 01:19 PM
HDJIM1158
Aug 13, 2016 07:38 AM
old kid
May 6, 2006 12:26 PM
