Transmission pulley swap
Old Jan 9, 2024 | 05:52 PM
hardheaded's Avatar
hardheaded
I went from the 70 to a 62 tooth pulley on the back of my 92 Heritage. Well worth the effort, it's not screaming on the highway any longer.
A128 tooth belt and 62 pulley is all you really need. But i changed the adjuster bolts and belt guards to the 93 part numbers. The bike has been like this since 1993 now.
Old Jan 13, 2024 | 09:41 AM
SparkyD's Avatar
SparkyD
I've been running the EV13, thinking about changing to the EV27
Old Jan 17, 2024 | 10:44 AM
TPost's Avatar
TPost
Starting the pulley swap this week. I'll let you all know how it goes.
Todd
Old Jan 17, 2024 | 11:35 AM
eighteight's Avatar
eighteight
Todd
I assume you have some variant of this varmint ?
Old Jan 17, 2024 | 11:57 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Seeing that you have a road King.. it would be very simple to pop the shift drum cover off the trans, pull the shift drum and then lock the shafts by putting them into two different gears.. It makes it much easier to get and nut on and off the fifth gear main drive gear..
Old Jan 17, 2024 | 12:32 PM
Greg55_99's Avatar
Greg55_99
This year, my belt broke. While getting it replaced I just swapped to a 65 tooth rear pulley and added an EV13 cam. Runs and pulls great. Lower rpms on the highway.
Old Jan 17, 2024 | 12:54 PM
TPost's Avatar
TPost
i assume you have some variant of this varmint ?
sure do
Old Jan 19, 2024 | 12:11 PM
86glider's Avatar
86glider
I had the EV27 first, then switched to the EV13. Didn’t like having to keep the revs up. I found the 13 much more pleasant to ride. Jmo.
Old Jan 19, 2024 | 12:56 PM
WP50's Avatar
WP50
The EV13 served us very well in a 97 EG with some head work and a good tune.
WP
HDvrod1967
VRSC Models
Oct 2, 2023 09:19 AM
dynamac
Mar 24, 2022 10:02 AM
Firemed80
May 4, 2015 10:10 AM
luvtoride
Oct 9, 2010 05:58 PM
Long124
Mar 1, 2010 06:45 AM
