99 softail won’t stay running
Old Feb 21, 2024 | 12:04 PM
evoowner87's Avatar
evoowner87
5th Gear
Default 99 softail won’t stay running
I’ve changed the battery, plugs, cleaned the carb but haven’t dissembled completely. Fresh gas. It will start and idle but once the choke is off it dies or it will run but under load it dies.
Old Feb 21, 2024 | 12:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Did this issue exist before you cleaned the carb?
Old Feb 21, 2024 | 12:24 PM
evoowner87's Avatar
evoowner87
5th Gear
no, the bike ran great, just yesterday is when it started spitting and sputtering on me then died and wouldn’t restart.
I got it home and cleaned the carbs and it seams to be running better but I’m concerned it’s deeper than a carb issue. You can drain a battery trying to get it to start with choke on. Once you push the choke in the bike will die.
Old Feb 21, 2024 | 12:52 PM
Wakko47's Avatar
Wakko47
After changing the plugs and the bike running for a while, what do they look like? Perhaps the carb to manifold gasket is compromised? Do you have blue spark?
Old Feb 21, 2024 | 12:54 PM
evoowner87's Avatar
evoowner87
5th Gear
I havent checked the plugs since changing them but i will today.
Its stumping me
Old Feb 21, 2024 | 12:59 PM
Dano523's Avatar
Dano523
What tank petcock in play, since could be as simple at broken vacuum line, or clogged petcock, and not supplying fuel fast enough to the carb in the first place.
If that is not the problem, then carb needs to come apart if adjusted correctly, since you screwed something up on the rebuild/most likely on the idle jet side, or did not adjust the float level correctly instead.
Old Feb 21, 2024 | 01:02 PM
evoowner87's Avatar
evoowner87
5th Gear
I didn’t disassemble the carb. I took the air filter off to access the carb, sprayed some carb cleaner in it around the needle and blew it out real good then put it back together. I’m not sure as to the tank petcock. I just bought this bike and I’m learning. Any help would be appreciated
Old Feb 21, 2024 | 01:15 PM
Wakko47's Avatar
Wakko47
Can you give is a bit more info? '99 carbed Evo, we got. How long have you had it and how many miles have you ridden with it? How many miles overall and do you know the history? If it sat, it could have a rusty tank and the screen on the petcock is clogged. Take a look inside the tank with a flashlight and see how the tank walls and floor look. You could also pop the fuel line off the petcock, run another line to a clear bottle, then turn the fuel to "ON" and see the flow. If you were riding it successfully and it suddenly started running like hell, a clog somewhere would be my first thought.
We'll get you there.
Old Feb 21, 2024 | 01:16 PM
steelpony16's Avatar
steelpony16
Genuine Harley-Davidson OEM Service Parts | Harley-Davidson USA
Old Feb 21, 2024 | 01:20 PM
evoowner87's Avatar
evoowner87
5th Gear
I’ve had the bike close to 2 weeks now, zero experience on older carbed bikes so I’m new to this.
I can say though I rode the bike from Danville ky to Harrison Ohio which is a little over 2 hours with absolutely zero issues. The guy who owned the bike before me took the best of care of it and it seems to be in pretty good shape. I haven’t looked down in the tank but I will today.
