Exhaust stud removal
Old Mar 4, 2024 | 12:57 PM
GREENOHAWK69's Avatar
GREENOHAWK69
When installing a new exhaust stud, how are they secured other then screwing them in tight (e.g. locktite)?
Old Mar 4, 2024 | 03:44 PM
Yankee Dog's Avatar
Yankee Dog
Last I heard about 10 ft lbs of torque are used for those studs.
The issue is: they are good and stuck from how long they have been in there, the heat cycles over the years, the oxidization of the steel stud in an aluminum head. Kind of like a cold weld.
I don't have much faith is getting the penetrating oil in where you need it unless you give it help by vibrating, shock, thermal expansion and then contraction by cooling, etc. You have to disrupt that oxidization "bond" to be able to get the penetrating oil in where it will help.
Old Mar 4, 2024 | 04:17 PM
PeterB's Avatar
PeterB
If heat and vice grips etc does not work and the stud ends up broken off flush, as they usually do, you can get a jig online to guide a drill bit to drill it out. Use a left-hand drill bit running in the reverse direction. It tends to unscrew what what is left of the stud as you go.
Old Mar 4, 2024 | 05:02 PM
Uncle Larry's Avatar
Uncle Larry
Jim's Tools makes a jig for studs ... As mentioned some heat and a good grip on the stud will probably do the trick ... Patience, patience, patience
Old Mar 4, 2024 | 06:40 PM
t150vej's Avatar
t150vej
Originally Posted by GREENOHAWK69
Was going to as 1 came out when I removed the exhaust. The others were in there pretty tight, so I left them.
OK,couldn't remember all the details. When I blew up the photo, I could see better.
The threads have a slight interference thread and do near bottom out. Looks like that one is totally bottomed since none of the blank is showing.
To install new ones, just double nut them, run them in till they're snug (only) take the nuts off and carry on with assembly...
You've gotten a ton of great advice on here. I've done a ton of ugly work like that on all kinds of machinery. Honestly, even with a welder and/or acetylene torch, it's a 50/50 at best you'll get it out while on the bike.That's a mean angle to work around. I recommend you pull the head and take to a general machine shop. have them both removed.
Old Mar 4, 2024 | 06:54 PM
GREENOHAWK69
I'm working on it now and will give it a go. My first thought and the most likely to happen is do my new favorite thing and remove the head and go to the bike shop or machine shop to have it removed.
Old Mar 4, 2024 | 06:58 PM
Uncle Larry
A wise man once told me if you don't have time to do it right, you won't have time to do it over ... As mentioned weird angles can make the job difficult ... Good luck ";>)
Old Mar 4, 2024 | 07:01 PM
t150vej's Avatar
t150vej
Well, ain't like you don't know to do it! Hang in there
Old Mar 4, 2024 | 07:07 PM
Ghetto blaster's Avatar
Ghetto blaster
I purchase an exhaust stud extractor from Oreily"s, worked like a charm.
Old Mar 5, 2024 | 02:57 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
It is way passed time for me on my 2017 but a guy did suggest every service moving the stud nuts to stop them rusting together. On the 2008 I have here the studs are clean and the I can get the header off easily as I have done it a few times now.
